tvpa creation pack:
karltoonz
tvpa creation pack:
Post by karltoonz »
i recently purchased the creation pack. the video cannon plug in will not install on windows vista.
rich
Re: tvpa creation pack:
hi Rich,
what version of tvpa do you have ?
malcooning
Post by malcooning »
Rich,
What is your indication?
does "video canon" not appearing in the plugins list?
Does the dll file show up in the plugins directory?
Is your camera capable of canon's "remote capture"?
karltoonz
Post by karltoonz »
hello all and thanks
i have tv animation pro 9 9.0.5
can you firstly check if you already have a "Plugins" sub-folder
in your C:\Program Files\TVPaint Developpement\TVP Animation Pro\ folder ?
anyway, if you have tvpa pro v9.0.5, you don't need to install the canon plugin
from this pack, cause this add-on is embedded now within tvpa pro itself.
not sure, but you can try to re-install tvpa pro (in custom mode), uncheck all items
and check only the Video Plugins/ Video Canon, then "Install" (see pict.)
karltoonz
Post by karltoonz »
thank you that worked!
you're a genius.
rich
