Crash help!
bullseye
Crash help!
Post by bullseye »
I was working on a project which probably had too many layers (over 20) and it crashed. Then it wouldn't open! Then it DID open! So I quickly copied the file to divide it into two projects (foreground and background) which I can assemble later. Well, the background project is fine, but the foreground project (which contains a lot of animation I don't want to lose!) crashes every time I try to open it! Is it hopelessly corrupted? Or might there be a way to open it? Help!
Re: Crash help!
Here is my suggestion :
1°) Duplicate your file.
2°) Export it as a 32 bits png sequence.
3°) Import it in a new, non corrupted project.
nb : When I draw I use to have more than 20 layers, so it should not comes from that.
How big is your file ? How much memory do you have ?
bullseye
Re: Crash help!
Post by bullseye »
How can I export it if I can't open it? If I copy the file, I can't open the copy. Also, if I open a new file and try to import the troubled file, it crashes.
Re: Crash help!
Please can you try to send us the file ?
We may help and do some quick tests.
bullseye
Re: Crash help!
Post by bullseye »
the file is 964.1 MB - how can I send it?
Re: Crash help!
please use this website : http://dl.free.fr/ (in french sorry)
bullseye
Re: Crash help!
Post by bullseye »
my francais is tres mal. any other way to send?
Hervé
Re: Crash help!
Post by Hervé »
bullseye wrote:my francais is tres mal. any other way to send?
yes, http://rapidshare.com/ ( or other ) but you must split your file.
Hervé ADAM, TVPaint Team
bullseye
Re: Crash help!
Post by bullseye »
i think i figured out how to send the file with the french site. what email address should i send it to?
Re: Crash help!
once the upload is finished, the dl.free website should give you a link to the download page.
Iggi
Re: Crash help!
Post by Iggi »
Hello I am experiencing the same problem right now, I have tvpaint 9.5.21
Did you fix the problem somehow?
Re: Crash help!
Iggi, no need to post 3 times the same problem in other topics, only one was sufficient ;)
Henk Beumers
Re: Crash help!
Post by Henk Beumers »
To all.
If you want to sent big files, use https://www.wetransfer.com/" onclick="window.open(this.href);return false; . You can sent file as big as 2 Gig for free. Also sequences of separate images are accepted. Most others do not.
Henk.
Henk Beumers
TVP 10.05.7 pro 64 bits W7 pro 64 bits. Intel i5 2.67. Mem 16gig.
