TVP Animation 9.5.21 is now available !
Re: TVP Animation 9.5 is now available !
ZigOtto wrote:
Elodie wrote: *The project tab becomes a storyboard tool : Now with TVP Animation 9.5, you can easily create a storyboard. This storyboard may be animated, printed, exported... A great new feature to make easier the animation workflow.
     *And much more ! To see the complete list, please have a peek on our website to see What's new on TVP Animation 9.5 ! You can also see all the differences with our previous softwares on this page.
@Elodie :
a) the link "What's new on TVP Animation 9.5" should bring the english version of the page, not the french one,
b) in the french version http://www.tvpaint.com/v2/content/artic ... atsnew.php, dans Outil de Story-board, il y a un doublon :
Comme les projets sont maintenant hierarchisés, le mode export se voit lui-même modifié : vous avez le choix entre exporter une animation (un clip) ou le projet en entier (ainsi que les brosses personnalisées, comme c'était déjà le cas avant).
ceci est écrit 2 fois, avant et aprés l'image d'illustration. une fois devrait suffire. :)
Ca s'affiche en français car ton ordi est en français (le site prend d'office la langue de ton OS, comme TVP).
Pour le doublon, c'est bon, j'y ai remédié =)
Klaus Hoefs
Post by Klaus Hoefs »
Hm. The old 9.05-version works with the newest Sentinel Driver - so it must be the 9.51mir (Mirage)- version who has a bug (I am guessing).
__________________
http://www.khoefs.de
Does TVP Pro 9.5 (Windows) install in a separate sub-directory?
How will the upgrade affect my existing 9.0.5 configurations and templates? Just asking before leaping. :?
Hervé
Post by Hervé »
Svengali wrote:Does TVP Pro 9.5 (Windows) install in a separate sub-directory?
In the same folder than the 9.0, you keep the same config
Hervé ADAM, TVPaint Team
downloaded and ran TVP_Animation_951_Pro_MIR.exe which installed TVP Animation 9 Pro.exe file - size 7,616kb - dated 9/7/2009 8:26 AM. Also installed Sentinel driver 7.5.0.
Clicked icon to run and got this error message. Rebooted. Same message. Removed and reinserted Dongle. Same message.
Sep. 08 tvp error message.jpg (14.31 KiB) Viewed 31601 times
what next?
Klaus Hoefs
It seems to be a bug.
I reported it already.
You can reinstall the 9.05 without problems until this may be fixed.
__________________
Hervé
Post by Hervé »
Svengali wrote:downloaded and ran TVP_Animation_951_Pro_MIR.exe which installed TVP Animation 9 Pro.exe file - size 7,616kb - dated 9/7/2009 8:26 AM. Also installed Sentinel driver 7.5.0.
what next?
Install the last service pack and xp update
Thanks Hervé, I'll try that...
Service Pack 3 is already installed... is there more I need to download from Microsoft?
Klaus Hoefs
You can go to
http://update.microsoft.com/microsoftup ... aspx?h=eng
Press Express to check your PC
After installing everything available it didn't help for me. So let's see.
__________________
Hervé
Post by Hervé »
Klaus Hoefs wrote:You can go to
This crash appear here on an old PC with a not up-to-date XP, a full XP update ( start->Microsoft Update) fix the problem.
If you don't want update your system, you can try to install this:
http://www.microsoft.com/downloads/deta ... 9C36F85647
http://www.microsoft.com/downloads/deta ... 4b9f2bc1bf
http://www.microsoft.com/downloads/deta ... 02b2af5fc2
http://www.microsoft.com/downloads/deta ... DA479AB0D7
Klaus Hoefs
Thanks Herve.
I've everything updated from the Microsoft-site and checked my system after restarting with their check-for-updates tool.
But I'll try also your links.
__________________
Klaus Hoefs
So after executing the files and restarting the problem still exists.
(I had already SP3 and three of your links were SP1 )
Sven, did you have more luck ?
__________________
Elodie wrote:Ca s'affiche en français car ton ordi est en français (le site prend d'office la langue de ton OS, comme TVP).
ha... c'est pour ça que chaque fois que j'installe une nouvelle version de tvpa, je choisis dans l'installateur language = english, et quand j'ouvre le nouveau tvpa, bingo : en français ! arghhh... :evil: je hais l'interface en français, (et bientôt les Français avec) ! :arrow:
il n'y aurait pas moyen que la langue (par défaut au 1er démarrage) de tvpa soit synchro (quand localisation dispo) avec la langue choisie dans l'installateur ?
en même temps c'est relou, mais c'est pas bien grave, juste exaspérant, ... aprés la 389eme fois que je re-installe le soft.
:wink:
sinon, depuis la page en anglais (le texte du lien est rédigé en anglais), je devrais rester en toute logique en Anglais,
quelque soit la langue de l'OS, un peu pénible ces sites qui ne tiennent pas compte des (derniers) choix du surfeur ... :roll:
Hervé
Post by Hervé »
Klaus Hoefs wrote: (...and three of your links were SP1 )
It's not XP SP1 but VisualStudio ( 95 and 98 ) SP1 redistributable files
Hervé (and Klaus),
I installed all the updates for C and the update for .NET 3.5 and I'm still getting the same error message. I'm totally down and can't get back to 9.0.5 either. Must I do an uninstall before trying to reinstall 9.0.5?
I also created a restore point about four days ago, and a registry. Should I revert?
Locked
