Here is the Shuttle PRO v2 from Contour Design currently listed at $109 USD.
There are set of nine keys at the top and four more at the bottom with two side keys. The jog wheel is centered inside of spring loaded shuttle wheel. I have three setups for use with TVP.. Drawing, Editing, and Animating. I page through these different setups using the side keys... left key is for previous page, right key is for next page. Popup at system tray at bottom of screen to tell you what setup page is currently active.
So, when in Drawing mode I use jog wheel to increase/decrease brush size. When in editing mode I use jog/shuttle wheels to move forward/backward through frames.. you get the idea!
Shuttle PRO knows what setup to use because of Windows focus. All software on your computer can be setup for use with this device. This is NOT a mouse! It only provides additional hotkeys for your use.
I am left handed. I have my tablet in front of me, stylus in my left hand, Shuttle PRO right side of my Intuous4, optical mouse sitting next to Shuttle PRO. My Logitech G11 keyboard sits in keyboard tray. Gateway widescreen notebook sits on shelf elevated above the Intuous4. It works for me
regards,
William
![Shuttle Pro v2 switch settings](./download/file.php?id=3565&sid=355751497ebb6c162fc091336e7d9e9b)
- Shuttle Pro v2 switch settings
- TVP9 switch settings.png (80.25 KiB) Viewed 3650 times
