Online SDK
Mads Juul
Online SDK
Post by Mads Juul »
Couldnt it be nice to have the SDK and especially the george commands online as a wikipedia then we could help each other to keep it up to date and with code examples etc
-mads
KenC
Re: Online SDK
Post by KenC »
Great idea.
An online wiki where we could store examples, tutorials, code snippets in a structured way would be nice.
I've worked a lot with MediaWiki which is what wikipedia runs on. It's very simple for end users to work with.
There's no place like ~/
Re: Online SDK
Ok, but the time is really missing here to do it. Can someone help ?
Mads Juul
Re: Online SDK
Post by Mads Juul »
Yes I would like to Help If you Just Set up the Wiki then the Users should do the rest like wikipedia
-mads
Mads Juul
Re: Online SDK
Post by Mads Juul »
And I'm also used to mediawiki like ken
KenC
Re: Online SDK
Post by KenC »
Yeah like Mads says once it's up and running users can update everything like wikipedia, in fact it's what wikipedia runs on.
I can write some help pages for new users to get started if needed, I've used it many times for documentation and manuals, it's very easy to use. If you can post on a forum you can use it.
The beauty of the wiki system is that everyone can correct each others errors and add things, so with time it just gets better and better.
We have a wealth of knowledge here with all the users that could be shared and benefit everyone.
Most webhosts have cPanel with a module called "Site Software" where it can be installed from, if it's not there the host just needs to add it and it's a couple clicks to install.
KenC
Re: Online SDK
Post by KenC »
On some webhosts in cPanel the addon to install extra software is called "Fantastico"
Re: Online SDK
madsjuul wrote:Yes I would like to Help If you Just Set up the Wiki then the Users should do the rest like wikipedia
-mads
ok, I have to search how to proceed. the idea is fine.
Mads Juul
Re: Online SDK
Post by Mads Juul »
Cool !
Re: Online SDK
Does anyone knows how to build a such Wiki ?
Mads Juul
Re: Online SDK
Post by Mads Juul »
we use mediawiki at work
http://www.mediawiki.org/wiki/Download" onclick="window.open(this.href);return false;
KenC
Re: Online SDK
Post by KenC »
I use mediawiki on my local intranet for documenting and storing everything I need to remember for years so I'm pretty used to it, installing it, installing extensions, admin backend, skinning, creating templates, .htaccess config etc..
Re: Online SDK
I remember Lemec have started something like this some times ago,
at least for listing all the Magic numbers available, as a begining. :wink:
KenC
Re: Online SDK
Post by KenC »
Fabrice, If needed I can break down the installation so it's easy to follow, I've installed mediawiki many times.
Re: Online SDK
Mike will take a look soon, he is more involved anything technical related to the web.
