custom cursors
malcooning
custom cursors
Post by malcooning »
Hey,
Is there any way we can create/install new CURSORS additional, or replacing the exisiting ones?
A.
TVPaint
Post by TVPaint »
Hi A.
unfortunately you can't install custom cursors but you can suggest some new ones that we will implement in the next minor update ;)
TVPaint
Post by TVPaint »
In addition to my previous post, custom cursors can't be installed externally of the soft as you may install papers or custom brushes. You'll need a little patch to install new cursors.
Have you examples of custom cursors you'd like to use ?
malcooning
Hey N.
Thanks for the patch offer. I followed Raymond's suggestion to use Restorator, so I created new cursor with Artcursors and saved them as .cur files and then replaced them with the existing 'circle' and 'dot'. I've attached jpgs of them below.
I didn't take the time to learn how to create patches, but maybe once I do I can post it up in the forums.
Cheers,
Asaf
pen - smaller.jpg (941 Bytes) Viewed 23079 times
fanany
Post by fanany »
a "must-have" would be to have the ability to swap between your 2 or 3 most favorite Cursors
via shortKeys or CP buttons,
for example, to swap from "Left-Up" to "Left-Down", and vis-versa, or from your "pen" to your "small one".
I would love that!
8)
malcooning
but if the cursors can be changed noly via patching, is there any way to implement such shortcut?
Of course I don't want to belittle the power of the programmer :)
it would be fantastic to swap about your cursors. the potential of different cursors for different usages is amazing.
malcooning
but the ultimate blow of all cursors in the world will be a cursor that rotates with the tilt and angle of the stylus!
fanany
Post by fanany »
malcooning wrote:but if the cursors can be changed noly via patching, is there any way to implement such shortcut?
I was pre-supposing new cursors implemented in the main code (extending the basis library), not through a patch.
just throwing ideas for new features in the next TVPA version or TVPS(?)
malcooning wrote:but the ultimate blow of all cursors in the world will be a cursor that rotates with the tilt and angle of the stylus!
I wouldn't dare ask that! :)
the ultimate, for sure, though I guess such a feature would tax time-computing,
and considerably slow down the "realtime" drawing display, unless you have a 5Ghz quad-core cpu machine...
(hope I'm wrong !) 8)
