SplatterBrush!
Re: SplatterBrush!
Well, force the install, to be sure =)
It works well on my mac.
masterchief
Re: SplatterBrush!
Post by masterchief »
malcooning wrote:sorry guys, didn't see those posts for some time now - I was on holiday.
Well, I'm back, and here are new year brushes!
(In the panel you'll find 2 brushes: Bristler - paint with this one initially, and Grunger - use it to mix and add some character. The purple colors are to be excused)
EDIT: for a better usage, remove the color command lines from both brushes' custom button commands, and then it won't reset to purple colors every time you select these brushes. If you struggle i'll upload a color-less panel)
enjoy
cheers... thanx for the brushes
regards,
William
TVPaint Animation Pro v11
mox
Re: SplatterBrush!
Post by mox »
I made a picture with those brushes, in the user gallery to see it.
Thanks again Chad! :)
Jerome Lorin
Moxica (playground)
(Win11/TVP 11.7.3-64 bits pro)
3Dementia
Re: SplatterBrush!
Post by 3Dementia »
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU ......Did I say THANK YOU! So much gratitude. :D
CartoonMonkey
Re: SplatterBrush!
Post by CartoonMonkey »
You're welcome, x1000!
lapprenti roi des singes
Re: SplatterBrush!
Post by lapprenti roi des singes »
Damn ! How come I missed this awesome thread !?
I Feel really grateful for your sharing, man ! You just answered some of my most anticipated requests !
Thanks a lot !
Besoin d'un lift? J'ai garé mon nuage pas loin...
CartoonMonkey
Re: SplatterBrush!
Oops! I had mistakenly taken down my SplatterBrush V3.
Here it is!
http://www.cartoonmonkey.com/SplatterBrush-V3.zip" onclick="window.open(this.href);return false;
Harlock
Re: SplatterBrush!
Post by Harlock »
Hi, I realise this is an older thread but I can't download the splatterbrush V2 and V3, just the V1 is still available. Is it still possible to get them? Thank you
TVP 11 Pro (11.0.8-64 bits), MacOS 10.13.6 - Wacom Cintiq 27 QHD
CartoonMonkey
Re: SplatterBrush!
Here they are!
attachment=0]SplatterBrush-V2.tvpx[/attachment]
SplatterBrush-V3.tvpx
(4.74 MiB) Downloaded 650 times
(16.6 MiB) Downloaded 564 times
Harlock
Re: SplatterBrush!
Post by Harlock »
Great! Thank you!
johnfromncl
Re: SplatterBrush!
Post by johnfromncl »
These brushes are great - my personal favourite is the Pressure Splat.
Many thanks.
iMac (Retina 5K, 27-inch, 2020). 3.8 Ghz 8-core Intel Core i7, 128GB 2667 MHz DDR4. MacOS Catalina 10.15.7.
TVPaint Animation 11 Pro (11.5.2-64 bits).
Wacom Cintiq pro 24". Driver using 6.3.43-3 (avoiding 6.3.44-1)
John from Newcastle, johnfromncl Updated 2021-09-24
