menu lettering blurred after version 9.511
wvreek
Post by wvreek »
Hi there,
After installing update 9.515 and 9.516 the lettering of all menus in TVP appear blurred?
see pictures:
9.516:
as opposed to the crisp and clear menus in 9.511:
Is there a way to change this back?
Thanks, Wouter
my machine:
Asus P6T, 12GB RAM, i7/720, windows7 64-bits, ATI Radeon HD4650
Re: menu lettering blurred after version 9.511
Hoi Wouter,
The last version now supports cleartype fonts and this should able you to choose your own font for TVP, but i'm not sure if/how this can help you with your problem.
maybe you should check your .loc file?
quote from Hervé:
You can edit the .loc file and change the font size yourself ( it's a text file, data/tvpaint.loc or data/french.tvpaint.loc line $00031)
(ik ben keepvogel fan)
Hervé
Post by Hervé »
Hi Wouter,
TVP ( since 9.5.12 ) use windows settings. To inactivate cleartype go to the windows preference panel -> display -> cleartype -> inactivate
Hervé ADAM, TVPaint Team
wvreek
Post by wvreek »
OK, that helps, thank you!
greetings,
Wouter
