Support for Dual Screen Monitors
Mishiek45
Post by Mishiek45 »
It would be a great help to be able to drag toolbars from on screen to another when working on dual screens. As it is, it won't let me stretch across multiple screens, feels a bit convoluted.
hilere
Re: Support for Dual Screen Monitors
Post by hilere »
Check the settings of your video driver, and the settings of your toolbars. I am working with triple screen setup without a problem. There's no limitations within TVP. Solution to be found in the driversettings of your video card.
hilere wrote:... There's no limitations within TVP. ...
but make sure the TVPwindow is not maximized, only then can you stretch it manually over your multiple monitors.
malcooning
Post by malcooning »
or work in "no border" mode.
It's in Edit > Preferences > Interface
If you want to be able to toggle this mode quickly, make a custom button and assign shortcut "TVP Animation: No Border" to it.
Kwadrope
Post by Kwadrope »
yes but detachable windows are a great comfort
your 2nd screen isn't necessarily as big as the 1st (cintiq?)
en then you need any space you can get
I would like to get rid of the menubar sometimes for example.
A work/zoom window (shortcut m) which I could bring "out" of tvpaint and maximize there would be great
