Creates a temporary blueline sketch that follows behind your cursor - Use this to make "airsketches" with the stylus by moving the stylus around without touching the tablet.
Lines are non-permanent and are confined to a small region of the screen that follows your cursor around.
Use it take "practise swings" and temporarily make markings on the screen without affecting your canvas or having to undo/redo.
Doubletap ALT to toggle it OFF/ON
Hold ALT to rapidly fade out the papertrail
Doubletap ESC to quit (or see the green task tray icon)
Tutorial is here
For PC only.
Papertrail Autohotkey Script
- papertrail_tvp.zip
- Papertrail_tvp.exe - Compiled TVPaint version (works for all programs but uses the ALT key for toggling and can be run standalone)
Papertrail_tvp.ahk - TVPaint version source code (if you want to modify it) - (208.78 KiB) Downloaded 2600 times
(Win7x64, TVP Pro 11 32-bit)
Re: Papertrail Autohotkey Script
Maybe later, but for now I am running on a tight deadline.
- malcooning
Mark this is a seriously cool tool. inventive, intuitive and practical. well done and thank you for sharing it.
Asaf | asafagranat.com
Glad you like it.
I will try to make some sort of options menu for it. (fade rate, line width, line colour, region size)
that's cool.... and the line of your papertail in your tutorial vid was awesome ... with line color and fading out... hope u add it to this script
