toggle marks or yellow stripes under drawing window
Stellamation
Post by Stellamation »
Does anybody know how to disable the toggle Marks (yellow line under the drawing window)
they prohibit me to draw
Thanks
malcooning
Re: toggle marks or yellow stripes under drawing window
Post by malcooning »
Not sure which mark you referring to.
can you post a screen grab?
crayon10
Post by crayon10 »
malcooning wrote:Not sure which mark you referring to.
I think the line is the one just below and in between the 'Markin' and 'Markout". Not sure how that would keep someone from drawing.
I think he means that yellow line :
In fact, that yellow line shows you the current image. As you only have 1 image, all the line becomes yellow. But if you add several images :
Only the current image will be yellow and so, the "yellow bar" will be thiner =)
Yellow "toggle Marks" ...? :? :?:
if it's what Elodie pointed in its interpretation, you can use the Toggle UI Visibility command,
the little black triangle in the preview window's top bar, and use shortkeys for reaching/using the hidden commands.
8)
