camera after project resize
Animark
Post by Animark »
is there a way to scale the camera together with the project size?
I have a project at 1920x1080 with some camera movements. I want to resize it to a width of 6000 pixel. I use the "modify project" function, but in the new project my camera stays with its original settings and I have to do the camera movements again.
Thanks from Animark
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Re: camera after project resize
Try to change the parameters, it should change all the camera's points at the same size =)
malcooning
Post by malcooning »
Animark wrote:Hello,
Thanks from Animark
There used to be a bug that caused the camera not to scale upon project modification. but it was fixed. do you have the latest TVP version?
Animark
Post by Animark »
Hi and thanks for your help,
unfortunately it doesn't helped ;-).
- I have the latest update
- I can change the parametres of the cam and it changes every cam-frame - but not the path.
- The cams width and height is changing automatically (scale) after resize, but not the path.
Here is a picture showing the project in 1920 (before) and 6000 (after). I think it demonstrates the problem very well.
I have a workaround for that problem (make kind of layout-level to have "markers" to reproduce the cam movement), but I would prefer not to place the cam a second time.
malcooning
I recreated the situation here, and upscaled 1920 to 6000, and my camera translated well, including the path.
see images (the 6000px is smaller here only because I zoomed out when I captured the screen):
May 30 22-46-41.png (46.8 KiB) Viewed 23571 times
May 30 22-46-21.png (56.92 KiB) Viewed 23571 times
I have the exact same problem and have brought it up recently as something that needs to be looked into.
Interesting; I replicated the exact move as well and it works -- the move follows the enlargement. This makes me think that there is some setting that makes it not work and I don't have that activated -- what could it be? :o
Animark
Post by Animark »
This is really strange. I tried several times, but never got good results. I tried with one and more frames, with cam locked and not, with different project sizes.
My TVP is 9.5.18. I think, it is the latest. Maybe you have a newer beta-version?
Yes, what could it be? :shock:
yep, bug not fixed in the 9.5.18 version.
It will be fixed in a future version of the product, which is still under development.
Sorry, please be patient. :oops:
Animark
Post by Animark »
I like to know if the bug discussed here is fixed in 9.5.21?
The problem exists still in my 9.5.21, but not at our filmschools 9.5.21 ( I am not 100% sure). So I am a little bit confused and would like to hear an official statement :?
Thanks from Animark
hi Animark,
it seems to work properly here since a (beta) v9.5.20 dated dec. 2010.
I also have an older version (sept. 2010) on another computer, with the bug still present.
so I guess every "post-december" public version should work fine.
now, you have to wait an "official statement" for the last words. :)
what's the date you get with "Help/about TVPA ..." ?
Animark
Post by Animark »
Hmh?
MY 9.5.21 is stamped as Oct 13 2011. Maybe I should reinstall my version - there must something went wrong with my updates :? . I miss the old forum posting with the 9.5 updates. It gave some orientation on when was an update published and what changed and fixed.
After reread your post and think: Are you sure with 2010? My bug report was from May 2011.
Animark wrote:...
not sure if it's the real date of this build, but it's the one announced with the "About ..." from the menu (dec. 13 2010). :?
in may 2011, (according to Malcooning few posts above), the bug was already fixed, but probably not released.
Animark wrote:MY 9.5.21 is stamped as Oct 13 2011
It is the good version and the good date....
Hmm, that's weird...
Animark
Post by Animark »
OK, I've tested the 9.5.21 - Okt 13 2011 at school and the cam-resize-bug is fixed in that version. I think my 9.5.21 at home is broken caused of some update trouble I had somewhere in the past. I will reinstall it.
But the bug-fixed cam in 9.5.21 have the same problems like the cam in TVP 10 I've written in the other post:
http://www.tvpaint.com/forum/viewtopic.php?f=10&t=5503" onclick="window.open(this.href);return false;
