Hi,
I may be being dumb, but I can't see any display of actual time in the interface, only framecount... can I get the time on the timeline, or at least a clock window somewhere else?
Timeline in seconds [solved]
- Eric Scholl
Re: Timeline in seconds
Hi,
You can see it by clicking on the "Image" button, under the layers colors, at the bottom on the left of the layer panel.
I have a small issue with the timeline numbers: it's always giving me frame numbers in 10s, or 20s or 50s, and in the timecode view very odd increments - anything but whole seconds. Since I often have scenes of longer than a minute this is quite uncomfortable for planning. It's not an issue when the timeline is short and everyother frame is numbered, but it gets in my way with timelines longer than about 50 frames.
What I do as a workaround now is to use the timeline notes: I set the grid to 24 or 25 frames so I can see the seconds. But this costs screen estate again.
What I'd like to have would be additional options in the Frame/Timecode button: "Seconds" with frame numbers like 12, 24, 32, 48, and a useful increment somehow marked in the little lines, like all 8 frames. This is not just tradition: this is the grid I have learned and use all the time for timing my animation.
The "timecode" option could be improved with marking whole seconds exactly.
that sounds great!
I found the button for timecode thanks
