Copy/Paste Blur
Copy/Paste Blur
Perhaps someone can help me with this blurring issue. Drawing in the demo version, if I copy a drawing and past it in somewhere the pasted version appears blurry- is there a way to correct for that? The blurring is subtle but noticeable.
Re: Copy/Paste Blur
Hello Jump,
Welcome in the TVPaint forum.
If you are copying/pasting with a custombrush, you should be able to change the Smooth option (none, medium and best), as shown below :
If you are using the transform tool, there is the AAliasing option to change in the same way.
Also, please try to use integer values (nothing after the coma), as shown below.
Re: Copy/Paste Blur
Whoa, that was quick... thanks a lot.
Re: Copy/Paste Blur
Yes, our software is our passion, so we are used to answer as fast as possible when someone is interested in it.jump wrote:Whoa, that was quick... thanks a lot.
With the time you will see that this community will become a part of your own familly.
Re: Copy/Paste Blur
Also if you are using the cut-brush tool to paste, make sure that paper texture is off, otherwise it will apply texture on texture and you will get a duller copy of the same drawing - happened to me a lot before I figured it out - by the way - its a note for TVP developers also...
https://vimeo.com/danas
Re: Copy/Paste Blur
ok, but how can we know if you will use the brush to move a part of an image or to create a drawing tool which will use the paper ...Soom wrote: its a note for TVP developers also...
Burshes have many way to be used ...
Re: Copy/Paste Blur
Yep - that's why we need a proper copy/paste function...Fabrice wrote:ok, but how can we know if you will use the brush to move a part of an image or to create a drawing tool which will use the paper ...Soom wrote: its a note for TVP developers also...
Re: Copy/Paste Blur
What do you mean exactly ?Soom wrote:Yep - that's why we need a proper copy/paste function...
There are already copy / paste function, for instances, layers, FX, brushes etc... You can even use the Select tool and copy your selection to a layer.
Re: Copy/Paste Blur
There were numerous requests about this copy/paste function. Currently there is no way to simply copy a selection and paste it on another frame of your choice. The action should be very simple - 1. Select part of drawing, 2. Ctrl C, 3. Ctrl V - thats it! The stamp tool and the copy to new layer etc, they are all workarounds, that require more manipulations than really needed.Elodie wrote:What do you mean exactly ?Soom wrote:Yep - that's why we need a proper copy/paste function...
Re: Copy/Paste Blur
Ok, I understand better now =)
Re: Copy/Paste Blur
But, well, in that case, use the custom brush and use the "stamp in place button". Yes, it's a CTRL C / CTRL V, but the result is the same and it takes the same time =)
Re: Copy/Paste Blur
But Elodie, we come back again to same issue that I mentioned in the start: Let's follow the procedure of copy/pasting with custom-brush:Elodie wrote:But, well, in that case, use the custom brush and use the "stamp in place button". Yes, it's a CTRL C / CTRL V, but the result is the same and it takes the same time =)
1. Select the cut-brush tool.
2. Make selection.
3. If you don't want to loose the drawing you are cutting, click Undo (in case the brush is set to Cut by default)
4. Now DON'T FORGET to turn off the paper texture, if it's on (and it's usually on in my case). If you forget, the pasted picture will not be the same.
5. Select the frame you want to paste to.
6. Go to Brush menu again, find the "Stamp in place button", which is usually somewhere far out of the visible interface, and click it. And I couldn't even find shortcut for it, so there is no way to use keyboard.
7. Select your normal drawing brush again to continue working.
Now lets see how it works with copy/paste:
1. Select selection tool
2. Make selection
3. CTRL C
4. Select the frame you want to paste to.
5. CTRL V
tats it...
Anyway - how many people actually use the cut brush to immediately draw with it? I think most people use it for copy-pasting anyway...?
Re: Copy/Paste Blur
I like the cut brush way, it's somehow less clinical than copy/paste. I can see how someone who is working to a deadline might want to speed up the process though.
Re: Copy/Paste Blur
I can see the need for simple copy & paste : " 1. Select part of drawing, 2. Ctrl C, 3. Ctrl V - thats it!" . That would be useful. Especially for some things involving single image illustration that would be easiest, but I find that for animation I prefer Select -- Copy or Cut To New Layer -- then Transform or reposition that portion of the image. Having a new "cel" layer to work with is easier for me to keep track of the different elements.Soom wrote:There were numerous requests about this copy/paste function. Currently there is no way to simply copy a selection and paste it on another frame of your choice. The action should be very simple - 1. Select part of drawing, 2. Ctrl C, 3. Ctrl V - thats it! The stamp tool and the copy to new layer etc, they are all workarounds, that require more manipulations than really needed.Elodie wrote:What do you mean exactly ?Soom wrote:Yep - that's why we need a proper copy/paste function...
Re: Copy/Paste Blur
I have learned something new: all this time I did not understand this . (i.e. "use integer values (nothing after the coma)") Did I miss that in the User Manual or does it need to be added to the User Manual ?Fabrice wrote: If you are using the transform tool, there is the AAliasing option to change in the same way.
However, most times when using Transform or Warp it is impossible to make the X or Y positioning precisely an integer value with nothing after the comma. Also when using Transform it is often not practical to keep Angle set precisely to 0∘, 90∘ , 180∘, or 270∘.
But I should say that I don't usually notice any blurring until I have transformed something several times . Just transforming once or twice to adjust size or angle on a drawing doesn't seem to have noticeable blurring.
