Change project start frame
ryberg
Post by ryberg »
Is it possible to change a project's start frame?
I've accidentally made a project that starts from frame 0 in the timeline. I'd like it to start at 1.
Do I really need to make a new project and copy the layers from the old project?
Re: Change project start frame
a script command allows you to change it :
tv_starframe [0/1]
go and see this topic : change the timeline startframe number
StartFrame.zip
ryberg
Post by ryberg »
Thanks
Keep Shooting
Post by Keep Shooting »
Starting to use the Georgescript. And I am trying to get this set startframe parameter to work, but I am probably overlooking something. Could you tell me where I go wrong?
Toolbar with button "1" > Edit > 0:Command: tv_StartFrame [1]
(working on OS 10.6 Mac)
Thanks, Conny
Keep Shooting wrote:Starting to use the Georgescript. And I am trying to get this set startframe parameter to work, but I am probably overlooking something. Could you tell me where I go wrong?
Thanks, Conny
I'm on Mac OS 10.6 and I use this custom panel that Herve uploaded in the Contents Sharing thread HERE :
StartFrame_1_0.zip
This requires no rescripting of the parameters to use. Just click on the "1" button: the start frame changes to 1 , or click on "0" button: the start frame changes 0. Nothing else to it.
Keep Shooting
Thanks, but I already tried to open this panel.
It will open a 'new toolbar' and it won't change anything in a 'new toolbar' when importing the 'custompanel.bin'...
folders custompanaldata has two files in it (buttons I suppose) and the cusompanel.grg is empty
(as the 'instancepanel' is working perfectly by importing the instancepanel.bin)
Am I missing something here?
Keep Shooting wrote:Thanks, but I already tried to open this panel.
Oh, ok, I misunderstood you from your previous post. I thought you were trying to change the parameters of the Start Frame custom panel .
I didn't realize you meant that the panel was not functioning for you at all.
This will need to be answered by someone more expert than me . I have no idea why it won't work for you . I am also on Mac OS 10.6 and it works fine for me.
Keep Shooting
"I thought you were trying to change the parameters of the Start Frame custom panel ."
Thanks. Sorry, I was not very specific indeed: I 'll try again to explain myself more clearly.
Importing the Hervé panel: it will not open when I import it.
But then it is no problem to make a custom panel with a button. And I found the StartFrame script in the wiki-george: when I apply that to a button nothing happens.
So my thought on this: I am missing something in the steps I would have to take to make it work and I am out of idea's on where that step would be.
Eric Scholl
Post by Eric Scholl »
Keep Shooting wrote: Importing the Hervé panel: it will not open when I import it.
Hi Keep Shooting,
Importing a custom panel won't open it. You have search it in the top menu. Go to "Windows => Custom panels => The panel you imported".
If you still don't see it, then search it in side panels.
I hope it will help you.
Keep Shooting
Hi Eric,
Thanks for your reply.
I will try to show what is happening:
[attachment=2]1_new-toolbar.png[/attachment]
I do get the custom toolbar, but without any functionality. And I do not see how to get it in there.
Any suggestions?
Thanks.
I open a new toolbar as shown
ematecki
Post by ematecki »
Hi keepshooting,
Were do you get these .bin and .data files from ?
In the posted zip file, there in a single .tvpx file.
You drop that .tvpx file onto a running TVPaint and it will be installed.
Maybe the app you used to decompress the zip does crazy ?
A+
Keep Shooting
"Were do you get these .bin and .data files from ?"
Wel I downloaded the link given earlier in this thread (on an iMac OS X 5.8 ) so it could be the OSses unzipper then.
Downloaded the file onto the MacPro (OS X 6.8 ) There it showed the .tvpx file. Still it would not install properly: it did not show the extension in the second "loading extension" window - the window was empty.
Then I tried downloading the last update of TVP (was working on 9.5 ), cleaned the preference-folder of all old folders and now it works fine!
Thanks, Conny
