Fabrice wrote:Thanks David,
Indeed, the more informations and helping people we can get, the sooner we can fix bugs.
Fabrice,
I am also in touch with Mark off-forum . It turns out he is one of our students at AAU online. I hope to speak with him on Skype later today to help troubleshoot the issue further. I've urged him to contact Elodie to try the test with the older versions of TVP using the Canon ZR 960 mini-dv camera , so we can try to isolate the bug in 9.5.18 . Or find out if it is some other system conflict that is causing the crashing. It's puzzling to me because not all students using the Canon ZR 960 report the crashing behavior , so I can't figure out what the common factor is that causes the crashing. (by the way , do crash reports help you ? If the student saves the crash report as a text file and emails it to you will that help isolate what the conflict is that is causing the crashes ?)
Here is what I know from my email communication with Mark :
Operating system : Windows 7 Home Premium edition, 64 bit mode.
Camera: Canon ZR 960 , attached to computer via firewire (IEEE 1394)
TVP version : 9.5.18
He has tried the camera using the freeware frame-capture app "MonkeyJam" and it worked . He was able to capture frames using MonkeyJam, so we know the camera and firewire cable are functioning correctly.
When he opens TVP Video Input window he can see the live video feed from the camera in the preview window. However, when he clicks on "Grab Input" to grab a frame there is an error message which pops up saying that TVPaint has encountered an error and then the program quits.
-DN
Screen captures below from Skype session to troubleshoot issue with TVP Video-Input crashing with Canon ZR960 mini-dv.
Device is showing as: "WDM".
Input: "Microsoft DV Camera" (does not show as Canon ZR 960 ... why ?)
Format: 720 x 480 DVSD
Clicking on Settings only brings up a single panel "Digital VCR Control" , nothing else. This is very different from Mac version of Settings panel
which brings up ability to adjust image as well as select the input device and set the compression codec (H.264 or whatever) . That surprised me , but I only know the Mac version , not Windows version.
We changed the Startup from Last Project Settings to Start Up Panel.
Could this be an issue with the WDM driver ? Does it need to be updated ?
I'm at a disadvantage here because I am not on a Windows computer, I'm on Mac, so I don't have
the experience working with Windows .
