Save separate layers
Manuel
Post by Manuel »
Here is the george script.
Use it at your own risk.
There is a path request at the start of the script.
Type a valid existing path.
Example : c:\
The layers are saved as avi
If you want another format you must edit the code.
Example :
if you want deep format change
Extension = ".avi"
tv_SaveMode "AVI"
to
Extension = ".dip"
tv_SaveMode "DEEP"
The layer's names are used for filename.
NO SPACE ALLOWED in the layer's name
Use different name for each layer.
If you find bugs, please report them here.
Thank you.
SaveSeparateLayers.zip
script
(571 Bytes) Downloaded 331 times
Manuel
Manuel
Post by Manuel »
If you don't want to type the path each time, open the script in a text editor and replace
tv_ReqString "Enter Path (ending by \)"
path = result
by
path = "d:\mypath\"
d:\mypath\ must be a valid, existing directory.
This way, all the files will always be saved in the same directory.
Manuel
Manuel
Post by Manuel »
Here is a special version that save in QuickTime format with alpha.
Don't forget to set up the path variable in the script.
By default, it is set to "c:\" .
IMPORTANT
You will lose your current brush if you use the script!!!
SaveSeparateLayersAlpha.rar
Qt alpha
(580 Bytes) Downloaded 346 times
Manuel
malcooning
Post by malcooning »
Manuel,
I kiss you. this script is perfect. works like a charm, and very smooth.
This should be embedded in the next release of tvpaint for certain.
Thank you for taking time to see to this script.
I wish I had the patience to learn the code and write my own scripts.
This will add a whole new dimension of tvpaint experince for me!
thank you millions.
A.
malcooning
hey Manuel,
I have tried to use SaveSeperateLayersAlpha.grg script in TVP pro, but something is not working right. When I run the script, it shows as if it is indeed exporting the layers, but no files are being added to the path that I put in the script (I made sure it ended with a \). I tried then the SaveSeparateLayers.grg, and after it brings the location request, it shows again as if it is exporting, but no files are written.
Can you please try the script in TVP pro?
cheers,
a.
Manuel
Post by Manuel »
Restart TVPAP.
Check your export file format.
Export one layer by hand to see if it works.
No space in layer name and path, try root path (c:/ d:/ ...).
Try the script on standard resolution (/16 ?).
Script not tested on Mac.
Manuel
malcooning
ah, of course, I made a mistake which was covered in September still...
The layer names - I didn't check for space in layer names...
it's fine now. Nowadays I'm not taking time to find the source of problems. I guess that life in London make me a bit impatient.
sorry to hassle you for this Manuel,
and thank you.
a.
fran125
Re: Save separate layers
Post by fran125 »
Hello ,
I ve try your script on TVPaint 10.0.11 but it s don t work.
The script create image but without any information on.
In fact i think the script hide all layer during export and don t show anyone.
Sorry for my bad english and thanks for your sharing.
fran125 wrote:Hello ,
Answering 6 years after the creation of the topic :?
Fran125, please introduce yourself, otherwise your message might be considered as spam.
If not spammer, please update your software to the lastest TVPaint Animation 10.0.17.
my1ironlung
Post by my1ironlung »
hey dudes i uploaded a tweek of this script. it will now export into seperate folders named L01, L02, L03, if you create the folders and specify a root path. also no need to add back slashes, and instead of using the layer name for the image names, you can make your own name when you put in the shot number. we needed this for a more professional pipeline.
one thing i can't figure out is how to get the layers exporting a hold at the end of the layer, or how to specify a mark in mark out point. but whatever. great job on the original script.
SaveSeparateLayersAlpha_namelayers_v02.grg
(1.82 KiB) Downloaded 299 times
my1ironlung
hello, well i guess no one cares anymore, but i updated this script, it now will only export the layers that you have turned on, any layers with visibility turned off will be skipped. it will however keep the naming order. for example if you have 3 layers, and layer 2 is turned off, it will export layer 1 and 3.
Again, make sure you have made folders for these layers: L01, L02, L03, enough for all your layers.
hope this helps someone out there.
harry
SaveSeparateLayersAlpha_namelayers_v03.grg
(2.32 KiB) Downloaded 322 times
my1ironlung
I'm very excited to see that they have included a similar script in the latest TVP 11 version. it really makes me love this software, as it seems that tvpaint really takes these forums into account.
i've tweaked their script a bit for optimization. it doesn't export unnecessary blank frames at the end of the sequence for layers that end early, and i've changed the naming conventions a bit so it is easier to import these images into another compositing software and keep everything in order.
Be careful not to include backslashes or any weird symbols in your layer names, it might have a hard time making the directories.
so here's the script:
#param none
tv_getpath "home" //path par defaut
srcFolder=result
tv_readuserstring "ExportDigital" "folder" srcFolder
srcFolder=result
//Ouverture du file requester
requester = FileRequester("<Select a folder to save in...",srcFolder,srcFile,"*.txt")
IF ( requester!=1 )
EXIT
END
tv_SaveMode "PNG" "b32"
tv_AlphaSaveMode NoPreMultiply
tv_layercurrentid
InitLayer = result
tv_layergetimage
InitImage = result
tv_firstimage
startingFrame= result
CurrentImage = startingFrame
tv_lastimage
LastImage = result
tv_clipcurrentid
ClipID = result
//tv_clipname ClipID
//ClipName = result
//these two lines above have been turned off, they identify the export by clip names.
//i've changed to project name below
tv_ProjectCurrentID
projectID = result
//tv_GetProjectName projectID
//ClipName = result
//tv_warn ClipName
tv_ReqString "hold up, what are we calling this? (ex: shot 1 = 'SH0010')."
ClipName=result
//run pre export sequence to create folders, folder paths and determine post behaviors ----------------------------------->
tv_LockDisplay "Initiating..."
layerRun = 1
layerCount = 0
WHILE ( layerRun == 1 )
    tv_LayerGetID layerCount
    layerID = result
    IF ( CMP( layerID, "NONE" ) != 0 )
        layerRun = 0
    ELSE
        //tv_Warn "layer " layerCount+1 " exists"
            tv_LayerSet layerID
            tv_LayerInfo
            PARSE result layerDisplay a2 a3 layerName a5 imagePos imageEnd a7 a8 a9 dummy
            IF ( CMP( layerDisplay, "OFF" ) == 0 )
              // postBehavior test
              tv_layerpostbehavior layerID
              endBehavior = result
              //tv_Warn "Layer" layerCount+1 "end behavior is " endBehavior"."
              test = CMP(endBehavior, "none")
              IF (test == 1)
                  layerBehavior[layerCount] = 0
              ELSE
                  layerBehavior[layerCount] = 1
              END  //end endbehavior test
              //-------------------------create folder,
              numlayer = layerCount+1
              foldername = pathname
              IF ( numlayer < 10 )
                  foldername = foldername"L0"numlayer"_"layerName
                  folderpath[layerCount] = foldername"/"ClipName"_L0"numlayer"_"layerName
              ELSE
                  foldername = foldername"L"numlayer"_"layerName
                  folderpath[layerCount] = foldername"/"ClipName"_L"numlayer"_"layerName
              END
              //tv_Warn "The folder path is " foldername
              tv_WriteTextFile "Exists" '"'foldername'"'
              exist = result
              IF ( CMP( exist, "0" ) != 0 ) //Si le dossier n'existe pas
                  tv_WriteTextFile "MkDir" '"'foldername'"'
              ELSE
              END
                     // ---------------------end create folder
            ELSE
            END
        layerCount = layerCount + 1
    END
END
tv_UnLockDisplay
//end pre export sequence to create folders, folder paths and determine post behaviors ----------------------------------->
    layerRun = 1
    layerPos = 0
        tv_LayerGetID layerPos
        layerID = result
        IF ( CMP( layerID, "NONE" ) == 0 )
          //tv_Warn "layer " layerPos " is being run"
            v3=layerPos+1
            //v1 = layerPos+1+layerCount*CurrentImage
            //v2 = layerCount*(LastImage+1)
            tv_LayerSet layerID
            tv_LayerInfo
            //tv_Warn "layer " layerPos " ending frame is" imageEnd
                    IF (layerBehavior[layerPos]==0)
                      endingFrame=imageEnd
                    ELSE
                      endingFrame= LastImage
                    FOR CurrentImage = startingFrame TO endingFrame
                        exportImage=CurrentImage+1
                          tv_LockDisplay "Exporting... (layer "v3", image "exportImage" )"
                        tv_layerImage CurrentImage
                        IF ( exportImage < 10 )
                          finalPath = folderPath[layerPos]"_000"exportImage
                        ELSE
                          IF ( exportImage < 100 )
                            finalPath = folderPath[layerPos]"_00"exportImage
                          ELSE
                            IF ( exportImage < 1000 )
                              finalPath = folderPath[layerPos]"_0"exportImage
                            ELSE
                              finalPath = folderpath[layerPos]"_"exportImage
                            END  // if<1000
                          END    //if <100
                        END    //if<10
                        tv_saveimage finalPath
                        //CurrentImage=CurrentImage+1
                        tv_UnLockDisplay
                    END //For current image
            END   // if layer is displayed
            layerPos = layerPos + 1
            ELSE  //the layer doesn't exist
            layerRun = 0
        END // if layer exists
    END //while layerRun=1
tv_layerSet InitLayer
tv_layerImage InitImage
//	FileRequester
//	Function: open a file requester
//	Call: FileRequester(title,path,file,pattern)
//	Arguments:
//	title   = requester title
//	path    = default directory
//      file    = default filename
//      pattern = default pattern
//	Return: 0 if user clicks on Cancel
//          1 if user chooses a file. This
//          function creates three global
//          variables: fullpath ( path+name+
//	extension ), pathname (path
//          to choosen file), filename
//          (name of choosen file without
//          extension) and extension
//          (extension of choosen file)
FUNCTION FileRequester(title,path,file,pattern)
LOCAL point slash size titre
    fullname = ""
fullpath = ""
pathname = ""
filename = ""
extension = ""
IF (CMP(pattern,0) == 1)
   titre = "|"
ELSE
   titre = "|"pattern
        extension = CUT( pattern, 2, LEN( pattern ) )
END
IF (CMP(file,0) == 1)
  titre = "|"titre
ELSE
  titre = "|"file""titre
END
IF (CMP(path,0) == 1)
   titre = "|"titre
ELSE
  titre = "|"path""titre
END
IF (CMP(title,0) == 1)
  titre = "Choose a file"titre
ELSE
  titre = title""titre
END
tv_ReqFile titre
fullname = Result
size = LEN(fullname)
fullname = Replace(fullname,"\","/")
IF (CMP(fullname,"Cancel") == 1)
    RETURN 0
    END
    fullpath = CUT( fullname, LEN(fullname) - LEN( extension ) + 1, LEN(fullname) )
    IF ( CMP( fullpath, extension ) == 1 )
        fullpath = fullname
        fullname = CUT( fullname, 1, LEN(fullname) - LEN( extension ) )
    ELSE
        fullpath = fullname""extension
    END
    start = 1
    stop = 1
    WHILE ( start > 0 )
        start = Find( fullname, "/", stop )
        IF ( start > 0 )
            stop = start +1
        END
    END
    pathname = CUT( fullpath, 1, stop - 1 )
    filename = CUT( fullname, stop + 1, LEN( fullname ) )
    RETURN 1
END
//	Replace
//	Function: replace each occurence of a
//            substring into a string with
//            another string
//	Call: Replace(string,search,repl)
//	Arguments:
//	string  = characters string
//	search  = substring to look for
//	repl    = replacement substring
//	Return: result string after replacement
FUNCTION Replace(string,search,repl)
LOCAL pos workstr str1 str2 size
pos = 1
workstr = string
size = LEN(search)
WHILE ((pos = FindString(workstr,search,pos)) > 0)
IF (pos == 1)
  str1 = CUT(workstr,size+1,LEN(workstr))
  workstr = repl""str1
  pos = 0
ELSE
  str1 = CUT(workstr,1,pos-1)
IF ((pos+size) < LEN(workstr))
  str2 = CUT(workstr,pos+size,LEN(workstr))
  workstr = str1""repl""str2
ELSE
END
END
pos = pos+LEN(repl)
END
RETURN workstr
END
//	FindString
//	Function: find a substring into a string
//             from a specified start position
//	Call: FindString(string,search,start)
//	Arguments:
//	start  = start position in string
//	Return: start position of substring
//	0 if substring does not exist
//	into string
//	-1 if invalid start position
//	(negative, null or higher
//	than string length) or if
//          substring is empty
FUNCTION FindString(string,search,start)
LOCAL found j pos lastpos lstr lsrch
found = 0
lastpos = start
lstr = LEN(string)
lsrch = LEN(search)
IF (CMP(search,"") == 1)
  RETURN -1
END
WHILE ((pos = Find(string,CHAR(search,1),lastpos)) > 0)
  j = 1
  found = 1
IF (j == lsrch)
  RETURN pos
END
WHILE ((j < lsrch) && (found == 1))
  IF ((pos+j) > lstr)
   RETURN 0
  ELSE
IF (CMP(CHAR(search,j+1),CHAR(string,pos+j)) == 0)
  lastpos = pos+j
  found = 0
END
END
j = j+1
END
IF (found == 1)
  RETURN pos
END
END
RETURN pos
END
//	Find
//	Function: find a character into a string
//	Call: Find(string,car,start)
//	Arguments:
//	car    = character to look for
//	Return: position of character
//	0 if character does not exist
//	into string
//	-1 if invalid position
FUNCTION Find(string,car,start)
LOCAL i size
i = start
size = LEN(string)
IF ((start <= 0) || (start > size) || (CMP(car,"") == 1))
RETURN -1
END
DO
IF (CMP(CHAR(string,i),car) == 1)
RETURN i
END
UNTIL ((i=i+1) > size)
RETURN 0
END
my1ironlung wrote:I'm very excited to see that they have included a similar script in the latest TVP 11 version. it really makes me love this software, as it seems that tvpaint really takes these forums into account.
We do take in account our users' needs, both on these forums and in real life too (when we visit studios and schools, or during animation fairs like Annecy or CTN Expo :D)
Thank you for sharing your own version of the script Btw :wink:
