as the topic headline
i want to make my work to be more handy ... that's what i love in tvp everything can be shortcuting
but for some tools doesn't
in drawing mode color and Erase shortcut works fine
is there a sulotion as dry toggle script ?
my version is tvp 9.5
why i can't make a Shortcut for "add" in mode drawing
Re: why i can't make a Shortcut for "add" in mode drawing
hi Hosni,
the shortcut command is available, it's Drawing Mode : 19 (Add),
if you want to assign it to a shortkey, you can go to Pref / shortcuts configure ...
then choose a free key leftside (or unassign one you don't use, say F9),
select "Drawing Mode : 19" in the right-side list, and clic on "Assign".
Hi Zig Otto
thanks for your response
yeah you are right >> i tested again and found it's work fine
but in smear brush i need to change from "color" to "add" manually ,
shortcut doesn't work in smear brush
what do you call Smear Brush ?Hosni wrote:... but in smear brush i need to change from "color" to "add" manually ,
is it the SpecialBrush tool in Smear mode ? ... or a CustomBrush in "Smear Stamp" mode ?
aha sorry
i meant a customBrush in "smear stamp" mode
well, it seems it have been fixed in V10.0,
the "Add" drawing-mode works as expected via the shortkey with a CB in Smear Stamp or Smear Color mode.
thanks ziggOtto
