tvpaint 10 issue-system error
TVPaint 10 issue- wandering pallets
This might be something that the programers might take a look at check out the upper right of the photo
there is a pallet stuck up there... I opend the program and there it was... I will restart to see if it clears the issue but
though the tvp people should see this...
my best djsolomon
my best djsolomon
See wandering pallet note...
I reinstalled and got this error message
has anyone any idea what the problem is?
thanks
djsolomon
thanks
djsolomon
- idragosani
Re: tvpaint 10 issue-system error
You have invalid plugins installed:
http://www.tvpaint.com/forum/viewtopic.php?p=11763" onclick="window.open(this.href);return false;
Hi idragosani , thanks for your repsonce... so I uninstalled
and clearly something is still funky as they pallets are still tucked up under the menu bar when i open the program
I really cant work know that clearly there is something wrong here...
what do you think may be causeing this ?
thanks djsolomon
thanks djsolomon
- idragosani
That I can't say, hopefully one of the TVP gang can help.
Hi idragosani- thanks again for your note..
No tvpaint gang yet...
how does one summon them ?
djsolomon
djsolomon
- masterchief
where is your palette found?? where did you go to select it for display on your desktop?? I do not see that palette on my systemdjsolomon wrote:Hi idragosani , thanks for your repsonce... so I uninstalled
thanks djsolomon
TVPaint Animation Pro v11
its the color variations panel, click around where the tools and panels are
you should see it
you should see it
- masterchief
- idragosani
They are probably closed down for the day (it's evening time in France now).djsolomon wrote:Hi idragosani- thanks again for your note..
hi djsdjsolomon wrote:...
I've no idea what's causeing this,
but you can try to start with a new config,
just to see if it solve this upset panel issue.
Sorry for the delay Debra, but as Idragosani said, we were closed when you wrote (8.00 PM in France)djsolomon wrote: No tvpaint gang yet...
I don't understand how you obtained that. Do the Variation panel opens like this the first time or did you put it there ?
As Zig suggested, I propose you to start a new configuration (start TVPaint and hold [Ctrl] to open the start up panel).
I had the same problem in v9.5 once with the papers panel: somehow I managed to drag it so high under the toolbar that I wasn't able to drag it back. This remained for weeks, until one day I was able to click exactly the one pixel which allowed me to drag it back. Strange.
