Unable to open or save files [solved]
Hi to All,
First off...i would like to say that i'm absolutely amazed by TVPaint and the work i've seen done with it.
Not sure if this is where i should come with my problem... this is the first forum i've ever joined so please bare with me.
Just purchased TVPaint 10 for mac. Was running demo for a bit and was aware of not being able to open or save files with demo.
So i was excited to receive the unlock code and everything seems fine except that "open" and "save or save as" does not work.
Does not work with system menu, tvpaint menu or even the icons.
As well as "temp directory" in preferences. I'm at a loss so any help or input would be much appreciated.
Things i've tried: re-install, restart, moving usb key and searching forum/website.
jci
jci
Re: Unable to open or save files
I feel like such a tool!
The simplest and most basic thing had me flustered.
File requester.
I have multi plane camera effect figured out but couldn't figure this out...sheeesh.
Sorry for the false alarm.
jci
File requester.
jci
Hi!jci wrote:I feel like such a tool!
File requester.
jci
What about the false alarm, did you solve it?
I have same problems as you had, if I'm using the systems file requester (set in the preferences) I'm unable to use save, save as or open, it works fine with TVPaints own file requester but not with the systems.
I am using TVPaint 10 pro v. 10.0.1 running osx 10.7.2
is this a bug?
regards Ulrik
I think it must be a bug then cause that's what's happening.
I'm just happy it's working right now by using TVPaint requester.
Don't know what else to do and don't really mind using it that way.
Sorry i couldn't help but if you find a way around it please let me know...i'll do the same.
jc
jc
It's a bug. We will fix it.jci wrote:I think it must be a bug then cause that's what's happening.
jc
Thank you Fabrice!
All's well.
Thanks Fabrice!
Thanks Fabrice!
the v10.0.2 is online, please download and install it, and tell us if there is still the bug.
Great news, thanks!Fabrice wrote:the v10.0.2 is online, please download and install it, and tell us if there is still the bug.
However I have not yet received my unlock code so I'm unable to download it, I hope I'll get it soon.
Cheers / Ulrik
Ulrik, we sent your codes three times !
I send them again by PM. =)
Thank you Elodie, I have received my code now.
Works like a charm although i think i have gotten used to TVP requester.Fabrice wrote:the v10.0.2 is online, please download and install it, and tell us if there is still the bug.
Thanks for the fix!
it's not a so bad requester finally.jci wrote:Works like a charm although i think i have gotten used to TVP requester.Fabrice wrote:the v10.0.2 is online, please download and install it, and tell us if there is still the bug.
Thanks for the fix!
I still get the bug.Fabrice wrote:the v10.0.2 is online, please download and install it, and tell us if there is still the bug.
Using TVPaint 10.0.2 on Mac OS 10.7.2 I can not use the Mac file requester .
Also, I can not set temp directory in Preferences. . Click on "Set" temp directory and nothing happens.
I don't have such a problem, neither with TVPaint 10.0.2 nor with TVPaint 10.0.3... =/
