Hi, I'm in the middle of tutorials, and finding myself falling into a state of smiley-faced joy at the richness of this program. I am, however, using the 8.5 version tutorials ( I know others are coming soon ) and can almost figure things out with the changes made since then - but am stumped on how to get the "blob" layer( Beginner tutorial #2) to go behind the image layer - ! the Tutorial says to go to the Animation Panel and then shows two layers and two arrows changing positions, but in the 10Pro I can't see where to do this. Can you help?
Thanks,
K
osX 10.6.8 intel iMac, i7MBP
Layer switch in demo TVP10
osX 10.7.5 intel iMac, i7MBP
TVP Pro 10.0.14
TVP Pro 10.0.14
Re: Layer switch in demo TVP10
not sure to answer to your "blob" problem, but you can change the layers order just by LMB-clic & drag the layer's head thumbnail
(to change its position in the layers stack, fore or back one each other).
... or use the shortcuts Ctrl-Up to move up the current layer, and Ctrl-Down to move it down .
It worked! thanks -ZigOtto wrote:not sure to answer to your "blob" problem, but you can change the layers order just by LMB-clic & drag the layer's head thumbnail
The "Blob" is in the old tutorials for V8.5...
TVP Pro 10.0.14
TVP Pro 10.0.14
Kathleen, you should maybe read the User guide for TVPaint v.10 than the old tutorials for TVPaint 8.5.The interface has so much changed, that I'm not sure it is very helpful
I think you are right, I will forgo the old tutorials until I get the 10 software - thanks,Elodie wrote:Kathleen, you should maybe read the User guide for TVPaint v.10 than the old tutorials for TVPaint 8.5.The interface has so much changed, that I'm not sure it is very helpful
TVP Pro 10.0.14
TVP Pro 10.0.14
You are very welcome
