I just got TVP 9 and it Automatically makes a new image when I draw something,
how can I turn this off?
thanks,
-MoC
Re: Automatically makes a new image when I draw something,
Top menu bar: Layer>Exposure>Auto Break Instance; uncheck.
Thanks a lot!Paul Fierlinger wrote:Top menu bar: Layer>Exposure>Auto Break Instance; uncheck.
- masterchief
Paul,Paul Fierlinger wrote:Top menu bar: Layer>Exposure>Auto Break Instance; uncheck.
please briefly describe end result of having 'auto break instance' checked and unchecked. thank you
regards,
William
TVPaint Animation Pro v11
With autobreak checked you can break into any portion of an instance (the gray length of frames following an image) by just drawing something in your project window. You don't have to use a key command or a custom panel button to break into a portion of an instance; as soon as your pen will touch the project window there's suddenly a new image frame wherever your cursor happens to be.
With autobreak not checked, you have to manually create a new image (that is, break into the instance portion of a layer) by using a key command or custom panel button.
- masterchief
thank youPaul Fierlinger wrote:With autobreak checked you can break into any portion of an instance (the gray length of frames following an image) by just drawing something in your project window. You don't have to use a key command or a custom panel button to break into a portion of an instance; as soon as your pen will touch the project window there's suddenly a new image frame wherever your cursor happens to be.
