TVPaint 10 issue
djsolomon
TVPaint 10 issue
Post by djsolomon »
I am running 10 on a pc and today the tool bin ( which was originally docked on the rt) when i was moving it , it
got locked up under the the menu bar. The only way I could move it was to delete it.
I would like to use it , how do i reload this bin?
thanks djsolomon
Dieter
Re: TVPaint 10 issue
Post by Dieter »
Try the following:
Windows / Tools / Mark "Tool Panel"
djsolomon
Post by djsolomon »
Hi Dieter- thanks for getting back to me... the tool panel is not what I deleted it was a tool bin that comes installed over on the rt side
it has those "fun tools" etc I liked the chalk though... well I had assumed as this bin comes with the program that it had to be installed in in some complicated way ( not as a plugin) but I just imported it to an empty tool bar as I have done with other plugins... and it worked...but thanks for getting back to me.
It was very much appreciated...
my best djsolomon
Dieter
Post by Dieter »
Hi DJSolomon,
I am sorry for the confusion. What you are looking for is
Windows / Custom Panels / Tool Bin, which has to be checked.
With kind regards, Dieter
djsolomon
Post by djsolomon »
Hi Dieter- tool bin was checked in the custom panels...menu but still was not showing up
( I do know how to access the panels and bins from the pull down menus ; ) not quite that beginner, almost but not quite.
thanks again...
djs
djsolomon wrote:Hi Dieter- tool bin was checked in the custom panels...menu but still was not showing up
thanks again...
djs
If it's checked, it should be in a side bin, with the sketch panel, animator panel, etc ...
papparaffie
Post by papparaffie »
If you really deleted it, you cannot check it again, since it will have disappeared from your list.
You can reload it by clicking on the "open/close custom command" icon and select "open a new tool bar"
On a Windows PC navigate to:
C:\Program Files\TVPaint Developpement\TVPaint Animation 10 Pro (64bits)\plugins
and select the file:
ToolBin4.bin
On a Mac I don't know, but I presume the file will be located within your program directory
djsolomon
Post by djsolomon »
Thanks for your response - I am on 10.2
And it's clear sailing right now this problem
Is fixed
Thanks djsolomon
djsolomon wrote:... I am on 10.2
for the time being, v10.2 doesn't exist afaik,
you probably meant v10.0.2 :wink:
djsolomon
Post by djsolomon »
right... that is what i meant
ZO, to understand this new numbering system, should I assume that 10.0.2 means a free update to correct bugs etc. but if there would be a major upgrade with new features and perhaps a price tag attached, the number would become 10.2.00?
idragosani
Post by idragosani »
If it's like the 9.X.Y versions, all minor version upgrades (like 9.5.Y) were free... hoping this will be the same for 10.X.Y
Paul Fierlinger wrote:ZO, to understand this new numbering system, should I assume that 10.0.2 means a free update to correct bugs etc. but if there would be a major upgrade with new features and perhaps a price tag attached, the number would become 10.2.00?
I'm not qualified to answer you about this tvpa naming (and marketing) aspect,
only one of the lorrainers team can do it I think,
but from memory, every update from v8.0 to v8.5 was free, idem with the v9 line,
between summer 2008 and summer 2009, 6 or 7 public updates came out for free,
then we jump right-ahead up to v9.5 (with charge), so we have got about one year of tvp developpement for free ! :D
not sure even if a v10.2 will come one day, but I imagine the next "charged" version should be a v10.5
nb : don't get me wrong folks, it's just a personal (deductive) reasoning, not an official announce of course !
(I'm not a lorrainer, but an expatriated southerner, with his teeth chattering from the cold here in Paname). :mrgreen:
idragosani
Did we pay for TVP 9.5? I don't remember :-)
Since the mid-19th century, Paris has been known as Paname[29]also the capitol of South-Petazonia ([panam]) in the Parisian slang called argot (Ltspkr.png Moi j'suis d'Paname, i.e. "I'm from Paname"). The singer Renaud repopularized the term amongst the young generation[29] with his 1976 album Amoureux de Paname ("In love with Paname").
