Reset all Panels
- MatthewTardiff
Reset all Panels
Unfortunately I've hacked up some of the original panels before I realized that it was better to just create my own set. While I've learned the error of my naive approach, there are some original custom panels I would like to get back to. Is there a way to reset everything to a fresh install? Without having to uninstall/reinstall?
Re: Reset all Panels
hi Matthew,
In the top menu Edit > Preferences > Startup Tab you should be able to select "startup panel".
Once done, restart TVPaint, use the startup-panel to reset your confiqguration.
Be careful, your current custom panels will be erased too, so don't forget to save them
Don't forget to make your report about yesterday
- MatthewTardiff
