Urgent! - Unable to import audio
Aaaaaaagh!
I've recently upgraded to winfdows 7 64bit and Installed TVP Pro 10. I am in the niddle of doing an animatic and now it seems like TVP doesn't recognise any audio.
I initially thought it was the clients wav file but that open fine in sound forge. Changing the sample rate doesn't help and TVP won't open any mp3's either.
This all worked fine under 32bit.
Anyone have any ideas. I need to get this working asap or use another app for my animatic.
Re: Urgent! - Unable to import audio
Hi Dave
Any 64bits codec pack ( like http://www.free-codecs.com/download/k-l ... 64-bit.htm" onclick="window.open(this.href);return false; ) should fix this problem
Hervé ADAM, TVPaint Team
Thankyouthankyouthankyou Thank You
I'll download and give it a go
AH. That didn't seem to fully clear up the problem, though I can seem to import MP3 versions of my tracks now.
Any idea why the WAV's might not be working in TVP? I can open them in After Effects, Sound forge, winamp and Sony Vegas?
- CartoonMonkey
C
Hmm... I don't have that problem.
EDIT: My list of audio codecs from TVP's export/import panel:
IMA ADPCM
PCM (which I use)
Microsoft ADPCM
GSM 6.10
CCITT A-Law
CCIT u-Law
Does anyone here have a different list?
IMA ADPCM
PCM (which I use)
Microsoft ADPCM
GSM 6.10
CCITT A-Law
CCIT u-Law
- idragosani
Actually, I am seeing the same issue on Linux now... can't load WAV files, even for projects that had soundtracks added previously. Running from a terminal, I see this:
./tvp-animation-10-pro
/usr/share/tvpaint-developpement/tvp-animation-10-pro/plugins/loader/FFmpeg.so: undefined symbol: _Z10av_rescalelll
nOS::LoadLibrary() : Cannot load library /usr/share/tvpaint-developpement/tvp-animation-10-pro/plugins/loader/FFmpeg.so: /usr/share/tvpaint-developpement/tvp-animation-10-pro/plugins/loader/FFmpeg.so: undefined symbol: _Z10av_rescalelllImportFunctionList() : LoadLibrary() failed : /usr/share/tvpaint-developpement/tvp-animation-10-pro/plugins/loader/FFmpeg.so
Appears to be a symbol mismatch in the shared library.
I can't confirm at the moment. I've just re-formatted my system again (And lost all my brushes because I forgot to back them up - bah)
Could this be a 64bit issue? I don't remember having it on my 32bit TVP?
- Eric Scholl
Yep, this problem ( for Linux ) should be fixed with the next updateidragosani wrote:Actually, I am seeing the same issue on Linux now... can't load WAV files, even for projects that had soundtracks added previously. Running from a terminal, I see this:
- Henk Beumers
Hi all.
I have the same codecs as in Paul's list. No problem to get any type of sound in. I use W7 pro 64. Can't remenber having that problem when I started to use W7.
Henk Beumers
TVP 10.05.7 pro 64 bits W7 pro 64 bits. Intel i5 2.67. Mem 16gig.
