Keyframer effect stops working
Recently the Keyframer FX just stops working until I restart TVPaint. Is it only me?
https://vimeo.com/danas
Re: Keyframer effect stops working
Do you have an error message ? Does TVPaint crash ? What do you exactly mean by "stop working".
Nothing extraordinary happens - no error messages, TVP works fine, only the Keyframer FX suddenly stops from applying to any layer. I've tried adding some other effects and they worked. Only the keyframer didn't. It happnes randomly, so I can't see any connection to other actions meantime.
A dumb question, but dumb things happen to all of us: are you highlighting all the frames before hitting apply?
Before even applying, the preview doesn't work either... Applying to one or more frames doesn't produce any result too.Paul Fierlinger wrote:A dumb question, but dumb things happen to all of us: are you highlighting all the frames before hitting apply?
Did you check "preview" ? Did you hide the HUD ?
Do you have the Keyframer box at the upper left corner checked and the appropriate C boxes (create) checked so that they show the letter D (ready to Delete)?
Well - those are basics - Preview is checked, HUD I tried both hidden and not hidden (when the HUD is on, I can see it and I can see the yellow frame move along the path, but the drawings on the layer stay the same).Elodie wrote:Did you check "preview" ? Did you hide the HUD ?
The box at the top-left I will have to recheck again when this bug happens again - don't see anything wrong meantime. The D and C boxes (you mean the keyframes) couldn't be possibly unchecked, because I can see the keyframes along the timeline and I can see the HUD and the path on the screen...Paul Fierlinger wrote:Do you have the Keyframer box at the upper left corner checked and the appropriate C boxes (create) checked so that they show the letter D (ready to Delete)?
Hmmm, could you post a screenshot (with FX stack visible and timeline) ?Soom wrote: The box at the top-left I will have to recheck again when this bug happens again - don't see anything wrong meantime. The D and C boxes (you mean the keyframes) couldn't be possibly unchecked, because I can see the keyframes along the timeline and I can see the HUD and the path on the screen...
I will do as soon as it happens again (lets hope not )Elodie wrote:Soom wrote: Hmmm, could you post a screenshot (with FX stack visible and timeline) ?
