possible bug in tvp10?
can't use the sketch panel 'erase only...' X buttons (that only erase blue, yellow, or black, etc) unless i'm on the actual HEAD of a layer. so- not in the midst of an image layer, or anim layer with the 'auto break' unchecked. other functions work when not on the head, like changing the color with the fx panel, or using a regular eraser or tool. just not the extremely useful 'erase only...' X buttons.
didn't occur in tvp8.
tvp10 bug? sketch panel 'erase only' X buttons only on head?
Charlie C
charliecanfield.com
Mac mini (M1, 2020)
chip Apple M1
memory 16 GB
(currently running Monterey 12.6)
Cintiq 22HD (2015), driver 6.3.36-2
charliecanfield.com
Mac mini (M1, 2020)
chip Apple M1
memory 16 GB
Re: tvp10 bug? sketch panel 'erase only' X buttons only on h
No problem here on my TVPaint Animation 10.0.9 Professional.
Which store did you go to find that one ?Elodie wrote:No problem here on my TVPaint Animation 10.0.9 Professional.
here : http://www.tvpaint.com/v2/content/artic ... update.php" onclick="window.open(this.href);return false;
- idragosani
When did 10.0.9 come out? What happened to 0.8?Elodie wrote:No problem here on my TVPaint Animation 10.0.9 Professional.
10.0.8 was used for non public update.idragosani wrote: What happened to 0.8?
Hervé ADAM, TVPaint Team
... and the demo DVD
- idragosani
I confirmed this behavior (10.0.9, Linux 64-bit). Create several instances of various lengths, use the sketch panel pencils and create lines of different colors for each instance. Go to a non-HEAD exposure, the X buttons don't work. My expectation would be to create a new instance HEAD with the colors removed (with autobreak on) or to modify the current instance (with autobreak off). I don't have an old TVP version around to compare, however.CharlieC wrote:possible bug in tvp10?
Ok, bug confirmed with my Mac 10.8 too
