turn off toggle cutbrush
ryberg
Post by ryberg »
I'm pretty sure I've set up earlier versions of tvpaint not to cycle through the different kinds of cutbrushes when repeatedly punching B, but I can't seem to do it now in version 10.
Re: turn off toggle cutbrush
Toggling between cut and copy was F2 and F3 in 9 and is in 10 as well. Of course the different cutbrush options may have different settings.
Mads Juul
Post by Mads Juul »
In "Configure Keybboard Shortcuts" (ctrl-k) Map You cutbrush key(Probably "b") to "Brush:Cut Freehand" instead of "Brush: Toggle CutBrush"
ryberg
Post by ryberg »
brilliant Mads, thank you.
I couldn't find it because I assumed it to be called something with cutbrush instead of "Brush:Cut Freehand"
Mads Juul
Post by Mads Juul »
ryberg wrote:brilliant Mads, thank you.
it is confusing ! A feature request to change the name?
ryberg
Post by ryberg »
:D
not the most pressing matter
