stamp in place for multiple frames
ryberg
Post by ryberg »
I'd love it if you could use enter to repeatedly re stamp in place with the cutbrush or if you could select multiple frames and stamp in place
Re: stamp in place for multiple frames
For that I use this key command combo:
Tools: Draw Dot+Layer: Next Image
ryberg wrote:... or if you could select multiple frames and stamp in place
it works here,
if your sequence is already timed (exposed), make a custom button with these 2 commands :
Tools: Re-Apply Custom Brush
Layer: Recompute Exposures
arrow, enter, repeat?
ryberg
Post by ryberg »
it works here,
doesn't "Re-Apply Custom Brush" need you to stamp the brush once in order to re apply or is it simply stamp in place right after you cut it out?
and, yeah, I also need to recompute my instances even though auto create instance is switched off.
ryberg wrote:...
make the 2 commands button mentioned above and try it ... you'll get the answer by yourself ! :)
in fact, no, "Re-Apply Custom Brush" applies it at its original place (at least it's how it works here), doesn't need to be applied once before.
btw, what's your tvpa version ?
ryberg
Post by ryberg »
well, it seem like I created some confusion since I'm using one of Juuls Actions to stamp in place which includes a smart function for the smoothing of the cutbrush. That action can not be applied to several selected frames.
I can do that if I simply hit the stamp in place under the cutbrush options or create an action like ZigOtto suggested. Thanks for that.
What I was aiming for in the first place though, was for enter to work as re apply for stamp in place as well.
