Input for George Script
brianottosen
Post by brianottosen »
Hi all
Does anybody know if it is possible to give parameters in a command line when I call a George Script.
In pseudo code something like:
C:\>tvpaint.exe myscript.grg -s 1920 1080
Brian.
Eric Scholl
Re: Input for George Script
Post by Eric Scholl »
Hi brianottosen,
I don't think it's possible for now, but do you need to do this only for changing the size of the export or is it for a more general case ?
We could have an alternate solution to do that only for the export size.
brianottosen
Whan I mean is how you normally set variables when executing scripts in more general terms. In fact I only used the -s 1920 1080 as an example because it's easy to understand.
I would like execute one command line like this:
"%ProgramFiles(x86)%\TVPaint Developpement\TVPaint Animation 10 Pro (32bits)\TVPaint Animation 10 Pro (32bits).exe" "script=X:\george\globals.grg" 12 7 monkey
Currently we are doing doing it by performing three steps:
1. Create X:\jobs\job.bat
2. Create X:\jobs\job.grg
3. Execute X:\jobs\job.bat
It works but adds more complexity to the submitter.
I was wondering if there is a better way.
X:\jobs\job.bat
--- file beginning ---
"%ProgramFiles(x86)%\TVPaint Developpement\TVPaint Animation 10 Pro (32bits)\TVPaint Animation 10 Pro (32bits).exe" "script=X:\jobs\job.grg"
--- file end ---
X:\jobs\job.grg:
foo = 12
bar = 7
type = "monkey"
doThis ()
doThat ()
EXIT
INCLUDE X:\george\globals.grg
INCLUDE X:\george\functions.grg
--- file end ---
Hervé
Post by Hervé »
brianottosen wrote:Hi all
Brian.
It's possible, you can set value to the current config with the cmd tv_writeusertring
ex: tvpaint.exe "cmd=tv_writeuserstring mysection myline myvalue" script=myscript.grg
In the script file use tv_readuserstring to get the value you want.
Hervé ADAM, TVPaint Team
