Update 10.0.13
Sewie
Update 10.0.13
Post by Sewie »
Has anybody noticed that this update goes very heavy on the processor and is therefore a is a bit more unresponsive than 10.0.12?
I first noticed that TVP was slower with the update and when I turned on my Task Manager (windows7) I saw that the processor often runs at 60-80% whereas with the same project in TVP 10.0.12 it went no higher than
30-40%.
(I'm on an i720, 12 GB ram, windows7.)
Animark
Re: Update 10.0.13
Post by Animark »
Mhm, I made the update two days ago and noticed, that there is sometimes the performance lagging a bit. Didn't thought about this behaviour is coming from the update - but will have a closer look now. Thanks for mentioned it.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Re: Update 10.0.13
You know, you might be onto something. I'm beginning to notice jerky playback in my project window and one very noticeable occurrence: I use a script to swap between an eraser and a pen as I draw -- I must do this swap a hundred times a day and I'm beginning to notice that sometimes a slight hesitation occurs between the tap on my keyboard and the actual swap taking place. Some gaps are actually quite lengthy... hmmm... Anyone else?
Sewie
Re: Update 10.0.13
Post by Sewie »
I went back to 10.0.11 to check. It's definitely smoother.
Animark
Re: Update 10.0.13
Post by Animark »
How did you downgraded? I have the last updates saved on my pc. Do I have to deinstall the whole TVPaint and so on, or is there a direct way to overwrite the 10.0.13 with a 10.0.11 update file?
Sewie
Re: Update 10.0.13
Post by Sewie »
I just overwrote it with the previous version and it worked.
neonnoodle
Re: Update 10.0.13
Post by neonnoodle »
Yes, also experiencing a delay - remarkable, as this is the first time I can recall TVP stuttering at all! I'm used to it in Photoshop... :roll:
Re: Update 10.0.13
Hmm, that's quite strange!
All of you are running TVPaint Animation 10 Pro 64 bit, on Windows 7, aren't you ?
Do the problems remain if you are working with the 32bit version ?
Is anyone on older Windows, Mac or Linux experiencing the same thing ?
Re: Update 10.0.13
I experienced the delays on the Public release and went back to Beta.
Re: Update 10.0.13
Hi there,
Is it a delay when using the playback or is it a delay when you paint ?
Re: Update 10.0.13
In my case there was no delay on playback; just in switching between pen and eraser and occasionally when drawing the stylus would "trip". I would call all my experiences "hesitations".
Re: Update 10.0.13
Paul Fierlinger wrote:In my case there was no delay on playback; just in switching between pen and eraser and occasionally when drawing the stylus would "trip". I would call all my experiences "hesitations".
hmmm, what you you mean by "trip" ?
Are you using TVPaint Animation 32 bits or 64 bits ?
Re: Update 10.0.13
When I draw, my line will suddenly stop and then catch up, giving a sensation of tripping over a bump in the paper. The same when using Svengali's SWAP script to switch between pen and eraser; it often makes me wait for the switch to occur. I am going back to the public version now to verify these lags.
Re: Update 10.0.13
After switching, first thing that happens is that playback works with hesitations as well; it's a kind of stop and go playback with very small stops every few frames.
Re: Update 10.0.13
Do you have the lastest wacom drivers ?
What are the preferences : is Wintab/Subpixel checked ?
