Update 10.0.13
Re: Update 10.0.13
Wintab and SubPixel checked, Latest Wacom (I think): 6.3.4-3
Re: Update 10.0.13
Great! I'm going back to the beta version -- it's hard to work on this one; I hadn't noticed before because I was on a main key drawings playback. Now that I have progressed to inbetweening I experience what Sewie described at first.Fabrice wrote:ok, got it.
900 Demo DVD where about to be burned ....
Re: Update 10.0.13
I have the same problems as Paul just described. During playback I also noticed (task manager) that the load on the processor is way higher than it is on version 10.0.11.
I'm on 64 bit. I haven't tried the 32 bit, though.
Re: Update 10.0.13
DO you still have the problem is you disable the Barbecue option in the preferences ?
Re: Update 10.0.13
So there's the squirrel!! I never noticed it comes checked by default. Unchecked BBQ and problem solved!
Re: Update 10.0.13
I just did a quick test; it looks like the problems are gone when Barbecue is off. Also the CPU load is far less during playback. With Barbecue on it's around 40-50% and with Barbecue off it's around 10-15% (!).
It was a quick test, though. Can someone confirm this?
Edit; I see Paul already did.
Re: Update 10.0.13
For some reason I'm hungry, now.
Re: Update 10.0.13
Have a carrot.
Re: Update 10.0.13
Put it on the barbecue!
Re: Update 10.0.13
I hope it didn't make you nut !Paul Fierlinger wrote:So there's the squirrel!!
- neonnoodle
Re: Update 10.0.13
I have shut off Barbecue, and this solved the stroke delay for a while - now I am finding that after running for a few hours, I'm getting slowdown again. The file is not very big, only 60 frames or so. Is there some kind of memory leak issue?
Re: Update 10.0.13
I don't think so.
anyway, we will upload a new fixed version soon, as soon as the developpers will be back in the office.
Re: Update 10.0.13
Hi Fabrice,
is there something new from the update-front? Today I have the chance, to get an update session for all clients at our filmschool - our admin is not so busy now, but it can change every minute .
1. Is the problem only relating to the 64 bit version?
2. Is there any way to get the 10.0.11 version? (We are on 10.0.7, and I think th 11 is better than the 7 or a buggy 13.)
Thanks from Animark
Thanks from Animark
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Re: Update 10.0.13
1. the problem exists on both architectures (32 and 64 bit). We fixed with bug, so a new version should be available soon.
2. not from the website but I can send you a link to the 10.0.11 (contact me by email)
