Well, i've an Apple iMac (Lion Operating system) and i uploaded the Update 10.0.14.
Ok, so, now i can see in Finder the folder that contains the upgrade for TVpaint. Now what i can do to get the upgrade active? I'm almost new on Apple, someone can help me please??
Easiest way to update is directly out of TVP. Start your older TVP version / under Help-Menu, click Check For Updates, download will start automatically / the installer will start the installation process with popping up.
Another way ( after downloading )is to look in your download folder and to double-click the installer.
Double clic on the .dmg file to open it.
This will open a window.
I suppose you can follow the directions there, that is, drag'n'drop the TVPaint icon, following the arrow, to the Application folder.
Then double clic on the sentinel installer and follow his instructions (basically accepting the EULA).
If you want to have TVPaint available from the dock, type Shift-Command-A in a finder window, this will open the Application folder.
From *that* window (*not* the one that opened when doucle-clicking the .dmg file), drag'n'drop the TVPaint icon somewhere in the dock.
