TV Paint 10 Won't Launch
hilary
Post by hilary »
I upgraded to TVP 10 a while back and have kept 9.5 on my PC (so I can still output to quick times if I want) it has worked fine for months. Last time I opened it I got this error
TVP Launch Error.jpg (38.24 KiB) Viewed 19408 times
and now neither of them will open at all - any ideas?
hilary
Re: TV Paint 10 Won't Launch
Post by hilary »
Hi Tech Support -
Sorry I bypassed the read me before post :oops: Specs are as follows:
Windows 7 Pro
64 Bit OS
10 GIgs Ram
Intel Core i7 CPU 930@2.8 GHZ
hello Hilary, is it when you open a specific file ? or when you launch the software ?
hilary
Post by hilary »
Hi Frabrice -
Just opening the software - no file involved. Should I just re - install?
OK so an update on this issue - my adobe software wouldn't launch either so I cleaned the PC (Cookies, temp files, defrag, and a scan for issues) rebooted and now I can open Adobe and TVP will launch but I am still getting the bad file error. Don't get it... :shock:
can you try to reinstall ?
hilary
Post by hilary »
Hi Fabrice -
If it keeps happening I will - the Adobe issue makes me think that something else is going on with my system :x
Thanks,
Hilary
if you hold the ctrl key when starting, then the startup panel should appear.
once in the panel, try to reset the configuration, it might help.
hilary
Post by hilary »
Hi Fabrice -
Do you mean starting up the system and resetting the config - or do you mean when specifically starting TVP?
Cheers,
HIlary
ematecki
Post by ematecki »
Hold ctrl when starting TVPaint.
hilary
Post by hilary »
Hi -
I updated TVP 10 to 10.0.14 and that seemed to work - thanks for the help!
Hilary :P
you are welcome, I look forward to see you again in a few weeks. :)
