export Transparency
ori
export Transparency
Post by ori »
I am having a problem exporting an image/or image sequence with Transparency.
I tried with the formats:PNG,Jpeg,Tiff
I tried with a "V" on the background and without the "V" on the background
and it did not worked for me.
Thank you for your attention
maryam
Re: export Transparency
Post by maryam »
Make sure the background is unchecked and when choosing PNG make sure to choose RGBA,
have a look at the image.
Screen shot 2013-02-09 at 22.02.38.png (41.67 KiB) Viewed 30379 times
Piasdatter
Post by Piasdatter »
We are experiencing the same problem
The same happens with Tiff. Help?
With the settings in the screenshot PNG and TIFF should have an alpha channel. JPG doesn't support alpha.
How did you test? If you re-import one of the exported images, does it have transparency?
Piasdatter
slowtiger wrote:With the settings in the screenshot PNG and TIFF should have an alpha channel. JPG doesn't support alpha.
If i re-import the images to tvp10, it doesn't have transparency.
These exact settings work in tvp 9.5.18
If i set the settings to 'alpha only' instead of RGBA, it doen't work.
RGBA(32bits) gives me the options of 'premultiply' or 'no premultiply'
I don't understand the workings of alpha channels, I guess.
If you go to clip - background and switch from 'color' to 'none' it fixes the problem.
This have no influence in tvp 9.5.18, so why does it have influence in tvp 10.0.14? Is it the 64 bit?
Can't reproduce on 10.0.11 mac. I get a PNG with transparency no matter wich BG colour is chosen.
Piasdatter
And we are running win 7. hmm
At least we got it to work, but I sure would like to know why.
Hello !
This is indeed strange, I've tried to reproduce this bug on a 10.0.14 but like slowtiger, I had transparency whatever BG color was chosen.
My guess is that one of your settings was not correct.
Piasdatter
are you exporting from 'Project: Display' ?
we just found out if we export from there it also works fine without switching the background to none.
It works in 'Project: Display' but not in 'Clip: Display', and the settings are exactly the same?
Piasdatter wrote:are you exporting from 'Project: Display' ?
I did it yesterday in "Clip: Display".
I've just tried to export from "Project: Display", an done it again from "Clip: Display". Both work fine.
Piasdatter
Good grief. I don't know what we're doing wrong here. All the computers do it, there's got to be a setting we've screwed with, and I've run out of ideas.
Any ideas?
Is it possible your bottom most layer is an image layer filled with the same color as your background? Is it clear to you what is referred to here as background color; the virtual color in the bottom left corner of the Layer Panel (which is not a layer of itself)?
Piasdatter
you mean like you would in photoshop? No I don't, I have an imagelayer with the background layout, but I click it off and it's not visible on any exports. I still get that white background unless I set the background to none.
Please can you send to Thierry your file ?
We will test if there is a bug.
