djsolomon wrote:Ok, so how can I plot a long pan with a zoom at the end with ease in and ease out - in this little space?
Here's my suggestion for when you need to combine a long pan with a truck-in at the end : Do the long pan move first up to the point where the pan has finished , then go to Project menu -- Render Camera to New Project .
Now in the New Project (which will have rendered your pan move) go to the last frame and stretch it out for however long you want the truck-in move to be --- let's say the truck-in is 96 frames , so extend the last frame 96 frames. Now set up the Camera Tool profile editor to hold (flat line) up to the point where you want the truck-in to start , then do the truck-in move over the additional 96 frames. And Render Camera to New Project. Now your scene will have the long pan combined with the truck-in at the end. (at this point if it all looks good you can just dump the previous "new project" that had rendered the pan move only) .
