More shortcut options
Many keyboard strokes are not available in the configure shortcut menu. Such as...:
I'd like to use those though, hopefully in the future all keyboard combinations will be available?
(control + arrow is available, but that's previous/next space on OS X, so it shouldn't even be possible to set those as shortcuts on OS X...)
(edit: this probably should be in feature requests. sorry)
- LukasKrepel.nl
- TVPaint Pro 11.7.5
- MacBook Pro i7 2018 macOS Sonoma 14.6.1 + PC Windows 10
- Wacom Cintiq 27QHDT + Wacom Intuos4
- YouTube.com/@ClubBaboo
- YouTube.com/@FrameOrder
Re: More shortcut options
+1
TVP Pro 11.7.1
TVP Pro 11.7.1
alt, shift and control can't be changed (and their equivalent on MacOSX).
That would generate too much troubles for both users, teachers and developpers.
sorry.
sorry.
I don't understand why it is possible to use "cmd-i" or "cmd-o" as a keyboard shortcut and at the same time it is impossible to use for example "cmd-;"alt, shift and control can't be changed (and their equivalent on MacOSX).
TVP Pro 11.7.1
TVP Pro 11.7.1
Hmmm ... Will check monday (no Mac at home sorry).Joost wrote:I don't understand why it is possible to use "cmd-i" or "cmd-o" as a keyboard shortcut and at the same time it is impossible to use for example "cmd-;"
Post here if ever it remains unanswered. (we are moving to a new bigger office, so it's difficult to follow all topics)
I also noticed there are some shortcuts that DO exist in the list, but simply don't work. You can assign functions to these keys, but it forgets them when you press 'OK' in the 'configure keyboard shortcuts' panel.
⌘1,⌘2, ⌘3, ⌘4, ⌘5, ⌘6, ⌘7, ⌘8, ⌘9, ⌘0
While we're at it: "⌘," is also missing in the list.
PS- Bigger office!
Fancy! Good luck.
PS- Bigger office!
- LukasKrepel.nl
yes that would be useful
<Ctrl> + <Tab> is also missing in the shortcut list on mac 64 bit. (but it's available in 32 bit if I recall correctly)
Are any shortcuts being added in 10.5?
I really miss Control Tab and also ⌘1,⌘2, ⌘3 etc.
- LukasKrepel.nl
In 10.5.1 the keyboard shortcuts are still not fixed (for mac).
I'm not able to use a lot of simple keyboard shortcuts like: "cmd 1" (and all other numbers in combination with the cmd button), cmd >, cmd /
and a lot of other shortcuts.
-I am able to assign cmd 1 as a keyboard shortcut, but when I try the shortcut, nothing happens.
-It is not possible to assign a keyboard shortcut to "cmd /" and "cmd =" (and a lot of other cmd combinations)
Is it possible to fix this in the next version?
TVP Pro 11.7.1
TVP Pro 11.7.1
Will this "bug" be fixed?...
TVP Pro 11.7.1
TVP Pro 11.7.1
Hello Joost,
As we had more urgent bugs to fix, this one hasn't been fixed yet.
I can understand,
But can you put it on the "to do list" now?
It looks like a basic bug that should be easy to fix (not that I know anything about programming...)
TVP Pro 11.7.1
TVP Pro 11.7.1
not so sure, it might be OS dependant.Joost wrote:It looks like a basic bug that should be easy to fix
It's already the case, since you reported it.Joost wrote: But can you put it on the "to do list" now?
