Doing animation and integrate a video on 2D layers = > ok
But mapping it on a 3D structure is not possible, at least in TVPaint.
To do so, you would need a 3D software.
Projection mapping
Re: Projection mapping
- idragosani
Seems to me that has nothing to do with software per se and is a multimedia presentation requiring both audio and video hardware. You can use anything to make the animation and the music.
"Projection mapping" is nothing but projecting something onto an irregular surface, preferrably with the content taking advantage of that. Just a buzzword.
@Gochris1Gochris1 wrote:Projection mapping:
http://www.youtube.com/watch?v=bnCsZ3CR ... e=youtu.be" onclick="window.open(this.href);return false;
Hi,
I would like to see the video of your link, but it says it is private. Is there a way to see it?
Thanks
Sometimes I can see better with my eyes closed
[Using Win 7, 64bits, TVPaint Pro 10 DEMO 64bits, Pentium Core 2Duo 3.0ghz, 8GB memory]
I think if you try it now, it will work for you.
Now It is working fine for me. Thank you @Gochris1
I was just curious to see an example of the projection mapping.... Interesting.
I once tried to learn Blender 3D, and I believe it is quite capable of doing that...
