Drawing with cintiq help
Please take a look at the video link iv'e attached :
https://www.dropbox.com/s/g9c1lt82oixd9 ... 1%20PM.mov" onclick="window.open(this.href);return false;
Basically the problem is that drawing with any pen/pencil is okay at first but after doing something else like adding another instance, the strokes become light and thin. Its really quite annoying. please help me fix this.
Re: Drawing with cintiq help
Well, it looks like a "bug" outside TVPaint.
Are you using the last version of TVPaint 9.5 Standard ?
If I remember well, it's 9.5.21.
hello,
If you write in the forum, I stop the discussion through email ...
Please keep every tests at the same place or nobody will be able to follow and help.
It sounds like the size of the tool was decreased to the minimum.
Is it a touch Cintiq ?
Please check both the Wacom and TVPaint preferences if there is no call to a shortcut reducing the size of the tool.
i cant seem to find the settings to turn of the pen pressure
I think the touch on the newest Cintiq is linked to the mouse wheel.
So just unactivate the corresponding shortcut in the TVPaint preferences shortcut panel, or unactivate the touch in the Wacom drivers.
"So just unactivate the corresponding shortcut in the TVPaint preferences"
where can i do this ?
thanks ! hope this works and will definitely shoot you an email if i have any problems.
it worked
