Snapshot
schwarzgrau
Snapshot
Post by schwarzgrau »
In After Effects there is a handy feature, which maybe could be useful in TVPaint too. You can take a snapshot of the current work area and can toggle this snapshot with a keypress. Could be useful if you need a character in a similar pose on two frames, with a lot of action in-between or if you need to change something, but want to keep a screenshot how everything looked before.
mox
Re: Snapshot
Post by mox »
You can use the ClipBoard for doing that (Edit>ClipBoard>CopyImage).
Jerome Lorin
Moxica (playground)
(Win11/TVP 11.7.3-64 bits pro)
schwarzgrau
Re: Snapshot
No, I guess my explanations aren't that clear.
I'll try to explain it with screenshots
1. In my example I'm on the first frame (#0) and take a snapshot of the current work area, by clicking on the "take snapshot" button.
Taking a snapshot in After Effects
2. Then I go to any frame in my clip (in this example frame 37)
Going to frame 37
Going to frame 37
3. There I click on the "show snaphot" button, which appears after taking a snapshot. Now the snapshot is shown as an overlay as long as I click the button or hold the shortcut.
display a snapshot
display a snapshot
This could all be achieved by creating a bookmark on the first frame and use shortcuts to switch between bookmark 1 and 2 I guess, but with the snapshot-tool you can display your saved frame, even if you changed your work area completly, cause it's something like an intern clipboard, which only contains one image.
I hope it's now a bit more clear, what feature I'm trying to suggest.
ematecki
Re: Snapshot
Post by ematecki »
You can use the spare image for this.
Hit [Shift-J] (Edit > Spare > Copy to spare, [Spare: Copy To]) to copy the current image to the spare image.
Then move to the other image.
Hit [J] (Edit > Spare > Swap spare, [Spare: Exchange]) to swap the current image with the spare, hit [J] again to swap them back in place, repeat at will.
schwarzgrau
Re: Snapshot
with this solution I need to press J two times, but except from that this is exactly what I'm looking for. Thank you a lot.
schwarzgrau
Re: Snapshot
Unfortunately the spare-image only contains the image on the active layer. Would be useful, if the user could choose if an image from the current layer or an image from all active layers get saved to the spare image.
Re: Snapshot
schwarzgrau wrote:Unfortunately the spare-image only contains the image on the active layer. Would be useful, if the user could choose if an image from the current layer or an image from all active layers get saved to the spare image.
you can make yourself a custom button which will copy the current display into the Spare page :
then hit the button (or use a shortkey), go where you want in the timeline, and press [J] to swap to the spare page,
(you 'll have to tweak the [J] shortkey by adding the command "Layer: Toggle Display All").
schwarzgrau
Re: Snapshot
Works like a treat! Thank you a lot zigotto.
I never noticed I can do custom actions like this.
