Here's a small panel I made that's really handy if you like to draw arcs and other notes on top of your animation.
Basically, it lets you have an image (not anim.) layer on top of everything set to 50%, where you can draw arcs etc.
Any of the icons create the layer if it hasn't been created yet.
The first button with the paper icon, lets you toggle the Overlay-layer (it toggles layerdisplay+lock/groupcollapse).
The two brushes are very bright line brushes for notes and arcs and go straight to the overlay-layer.
It's a very simple tool, but very useful!
(edit the first two lines of the buttons if you want to change the name and colorgroup you want to use, right now it uses "Overlay ref" and colorgroup "1")
Overlay panel (easy to draw arcs etc)
- LukasOverlay.png (7.33 KiB) Viewed 1923 times
- LukasOverlay.tvpx
- (173 KiB) Downloaded 281 times
- Lukas Sketch Panel
- TVPaint Pro 11.7.3
- YouTube.com/@ClubBaboo
- YouTube.com/@FrameOrder
Re: Overlay panel (easy to draw arcs etc)
Handig! lekker bezig Lukas.
thanks
thanks
Hi Lucas
It's a nice panel, but I'm not able to change group's color - I change the number in the second line of the george script, but nothing changes...
https://vimeo.com/danas
Oops, my bad, try this one. (you have to change the number in all 3 buttons)Soom wrote:Hi Lucas
- LukasOverlay.tvpx
- (179 KiB) Downloaded 255 times
Great! Works well now, thanks!
- schwarzgrau
really useful thank you Lukas
