Hi
is there a way to make the color squares in the Bin section a bit larger? they are so small that every time i click one the color that is next to it is chosen instead. and also, the click i make creates new colors over and over again so i need to delete them every time
(i have TVPaint Standard Edition on a mac osx)
have a lovely weekend,
Shiran
color bin
Re: color bin
Its not possible but its a good request, these squares have been so small since Amiga days when monitors were much much lower in resolution.
Would you like them 2x or 4x bigger?
Let us ask the team to put this in for you, meanwhile you can use the mixer, did you know you can load any image into it, and if you active the bottom right picker(yellow) you can one-click-pick from your custom palette.
