Some problem in inputing Japanese on Mac
chainzhang
Post by chainzhang »
The TVPaint's interface will be broken(disappear) when I try to input Japanese to Action, Dialog or Note.
like this:
スクリーンショット 2013-10-04 16.29.28.png (87.9 KiB) Viewed 7246 times
Note that English is OK. The version is 10.5.2.
How can I solve the problem.?
thanks.
Re: Some problem in inputing Japanese on Mac
Which OS do you have ?
Is your OS also configured in Japanese ?
chainzhang
Fabrice wrote:Hello,
The OS I use is OS X 10.8.5.
I had tried to configured in Japanese but the result was the same.
Bug confirmed. This is indeed very strange.
We'll look into that.
In the meantime, you can fix it by changing the window size, the interface will be back to normal.
