[SOLVED] Is there a better way to manage the Custom Icons?
Soom
Post by Soom »
I would like to delete or reuse the icons I have created before. I have found a folder where TVPaint stores those icons, but it's a mess I wouldn't even dare to get into. The file names are just a bunch of characters and there is no way to preview them quickly, so I need to open 100 icons one by one - not the best solution : /
Is there any other way?
If not - i suggest to create an Icons Manager panel which will include renaming, deleting, adding new, grabbing and sorting the icons with dropdown separators (just like we can do on any other panel)
https://vimeo.com/danas
mox
Re: Is there a better way to manage the Custom Icons?
Post by mox »
During the installation, if you checked the "Thumbnail" option, you should be able to see and browse all the .dip files in your folders and your favorite pictures viewer too.
Jerome Lorin
Moxica (playground)
(Win11/TVP 11.7.3-64 bits pro)
Soom
Post by Soom »
mox wrote:During the installation, if you checked the "Thumbnail" option, you should be able to see and browse all the .dip files in your folders and your favorite pictures viewer too.
I didn't understand the first part about installation, but I managed to view the thumbnails with XnView - so this question is solved! thanks. I still do think TVP could implement some kind of basic icons viewer.
Re: [SOLVED] Is there a better way to manage the Custom Icon
That's because the Thumbnail option to check is only for Windows versions.
Thumbnails also work on Linux.
Soom
Post by Soom »
Fabrice wrote:Thumbnails also work on Linux.
They don't work in Total Commander on Windows though, that's why I asked - I don't use Explorer on my work Windows computer... cause it's in French :/ and I can't even get to the hidden folders (and they are hidden)!
The bigger issue, a better way to manage Custom Icons, still has many UNRESOLVED issues... perhaps a new Icon manager will come with TVPaint 11?
Drag and drop buttons: easily reposition buttons within a panel and move/copy buttons between panels.
Option to rename icon-files already assigned to buttons and have them maintain their existing button associations?
Button icon design utility for creating and editing individual icons?
Svengali wrote:The bigger issue, a better way to manage Custom Icons, still has many UNRESOLVED issues... perhaps a new Icon manager will come with TVPaint 11?
yes, there is a lot to do in this part of the software. :?
mox
Post by mox »
I set up a Total Commander's folder in "thumbnail view" and I can see the *.tvpp and *.dip thumbnails, same as Explorer or XnView (still the best viewer to display this kind of pictures anyway).
Jerome Lorin
Moxica (playground)
Soom
Post by Soom »
mox wrote: I set up a Total Commander's folder in "thumbnail view" and I can see the *.tvpp and *.dip thumbnails, same as Explorer or XnView (still the best viewer to display this kind of pictures anyway).
Weird - how did you get it to work? Which version Windows are you on?
Svengali wrote:Drag and drop buttons: easily reposition buttons within a panel and move/copy buttons between panels.
Yap - I already had a request on that - an appropriate palettes managing system would be a great improvement
mox
Post by mox »
Windows 8 and TC 8.01
To see the icons, I switched to the options "thumbnails" from the top left menu, 4th button for me.
If it works with Explorer and XnView, it should work with other viewers too, since it's a system thingy. :)
Jerome Lorin
Moxica (playground)
same on my laptop, with the same version of Total Commander
Soom
Post by Soom »
mox wrote: Windows 8 and TC 8.01
Yes - I know how to set Thumbnails view in TC, but they show blank square. I am on Windows 7, TC 8.01...
Actually - I just checked, and my windows explorer also doesn't show those thumbnails, so the problem is on a system level probably. only XnView shows them well...
is the .tvpp extention linked to TVPaint ?
Soom
Post by Soom »
Fabrice wrote:is the .tvpp extention linked to TVPaint ?
Yes , of course
