Anti aliasing with line colorize
Hello.
Is there a way to make the anti aliasing with the line colorize effect work between two colors?
I'm experimenting with the effect for my graduation film and I think it is a nice tool. It just pixelates my lines if they are surrounded by two different colors.
- Example of anti aliasing problem
- AAliasingLineColorizeTVP.JPG (58.06 KiB) Viewed 30392 times
Re: Anti aliasing with line colorize
Does it happen when you keep each color on a separate layer?
Yes this example is with each color on a separate layer.
I tried a version where I added the line colorize effect one time with only some of the color layers active, and then adding the effect again with the other color layers active. This gave a better result, but it would be nice if we did not have to do this workaround.
Well, it depends also on your line =/
Can you send us the original file ?
Yes of course
The line is on the layer called Cln_Black and the colors on color1-3.
- VR_DioWalk_TEST_012_CK.zip
- (5.2 MiB) Downloaded 1081 times
I just made a quick test, and I can report same issues.
No antialiasing even though it is enabled Then I tried to disable AAliasing and noticed no difference? I
- AA_test.zip
- (16.65 KiB) Downloaded 1080 times
You're right, no AAliasing.
I report this bug
I report this bug
Thank you very muchElodie wrote:You're right, no AAliasing.
I report this bug
Was this ever fixed? I'm having the same problem now...:/
Not yet =/
Do you know when there might be a fix/update for it? I'm new to all this so can I just ask, the only other way of changing line-art to block colours is to paint over the lines individually with preserve transparency on?
Will see tomorrow if the dev team can fix it quickly.Andrew14 wrote:Do you know when there might be a fix/update for it?
Yes, that's it.I'm new to all this so can I just ask, the only other way of changing line-art to block colours is to paint over the lines individually with preserve transparency on?
- Eric Scholl
Bug fixed in the next release
Wuhuuu, thank you!Eric Scholl wrote:Bug fixed in the next release
