setting the default tools?
Hi, is it somehow possible to adjust the default values of tools? So everytime I start TVP CTP I would have the same settings. For example Fill tool would have thees settings: Smooth 2, Gap Closer 2, Expand 2, etc...
It's not big problem, but would help a bit.
Re: setting the default tools?
CTP??! You're on the wrong forum. I had no idea anyone uses Crater anymore... how is it; which upgrade is CTP on now?
I ment TVP of coarse. Attack of dyslexia...
I used CTP for one film. Coloring whit it was smooth.
You must be my age
TVP can remember everything, size, color, paper if you use that... but you have to make a Custom Panel for your tools and after doing that you MUST save it (anywhere) otherwise you might loose it if TVP or your computer crashes. Do a search around here or look up the manual to learn how to save your tools in a Custom Panel... it's easy and the topic has been rehashed ad infinitum.
EDIT: ad infinitum et ultra.
Yes, Custom panels I can do, and I use those. With custom panel I can set the tools and use it again and again.
But it's not possible to set - or adjust - the default tools in tools panel? Custom panelt don't do that. Or is there trick to set custom tools to be default tools?
CTP was cheap and ok program in year 2006. It seams that they are making it still. I think it was ok program for one man studio. Now I really like TVP with Cintiq. No paper, no scaning is so much faster, and I don't loose the handmade touch.
Well, the tools do remember the last settings you used, don't they?
check in the preferences the startup tab : does the software remember the last used config ?
Yes, the Startup conf. is set to remamber the last used conf., but it doesn't effect on default tools.
I am using newest standard version of TVP.
which version number ? 10.?.?Tatu wrote:Yes, the Startup conf. is set to remamber the last used conf., but it doesn't effect on default tools.
Yes, TVP remembers some of the settings of Fill tool, like Gap Closer, Expand, Range but not Smooth, Opacity and Source.
I confirm this . On my Computer The Fill tool does nor remember Smooth and Opacity(Didnt test source)Tatu wrote:Yes, TVP remembers some of the settings of Fill tool, like Gap Closer, Expand, Range but not Smooth, Opacity and Source.
-Mads
Pen Brush remembers the settings, but the eraser tip (on cintiq pen) don't.
