Highlight frame range --> Faux-Fixe
neonnoodle
Post by neonnoodle »
I would like it if I could highlight across a range of frames, then right-click the frame where I want the Faux-Fixe to start and have it automatically assign the selected frame range as the loop. Does this make sense?
Re: Highlight frame range --> Faux-Fixe
+1. Makes a lot of sense. Saves me from counting frames, mis-count, readjust, etc.
It's a great idea, but in the meantime, do you know that you can see the frame count on the top bar of the Layer Panel, while you drag your cursor (and the same on the left of the bottom most bar)?
Hm, it's there, but not very prominently. I'm undecided whether I'd like it to light up during dragging.
Or better yet, on a small floating panel of its own. I need to see the frame count all the time in other instances besides Faux Fixe.
Paul Fierlinger wrote:Or better yet, on a small floating panel of its own. I need to see the frame count all the time in other instances besides Faux Fixe.
+1 8)
how should it looks like ?
