repositioning an image within a frame?
BruceM
Post by BruceM »
Can someone tell me how to reposition a drawing within a frame? I've copied the starting frame of a character walking across screen, and I want to position it at the other edge of screen so that I can tween to it. I want to basically slide the drawing from one side of the screen to the other.
Re: repositioning an image within a frame?
BruceM wrote:Can someone tell me how to reposition a drawing within a frame? I've copied the starting frame of a character walking across screen, and I want to position it at the other edge of screen so that I can tween to it. I want to basically slide the drawing from one side of the screen to the other.
You can use the KeyFramer in the FX stack or use the Transform Tool in the Main Tool Panel .
KeyFramer FX -
Transform Tool:
In both screen captures I have the light table on to show the previous position (in green) and the new position of the drawing by shifting it over using the KeyFramer or the Transform Tool.
(this question should be moved into Technical Support forum because it's not concerned with Contents Sharing)
D.T. Nethery wrote: (this question should be moved into Technical Support forum because it's not concerned with Contents Sharing)
Topic moved :)
BruceM
Post by BruceM »
Thanks so much D.T.!
And yes, someone already pointed out that I'm in the wrong area for my question.
