Mac OS X 10.9 Mavericks and TVPaint Animation
ten_zero
Re: Mac OS X 10.9 Mavericks and TVPaint Animation
Post by ten_zero »
A deletion requested post.
Thanks for the feedback !
I'll look into it.
Okay, the bug is 64-bit specific, and not related to Mavericks. However, the bug is not here in the 32-bits version, so you should use the 32-bits version until a fix is available.
Alternatively, if you want to use the 64-bits version anyway, you can also resize the window after you type the text : the interface should redraw itself.
ten_zero
Post by ten_zero »
ten_zero
Post by ten_zero »
ten_zero wrote:Apple ; Changes in OS X 10.9.5 and Yosemite Developer Preview 5
https://developer.apple.com/library/pre ... 1-TNTAG205
If your team is using an older version of OS X to build your code, re-sign your app using OS X version 10.9 or later using the codesign tool to create version 2 signatures.
Apps signed with version 2 signatures will work on older versions of OS X.
http://readwrite.com/2014/08/05/apple-o ... apps-block
No biggie, only 40 of my apps will break after Changes in OS X 10.9.5 and Yosemite Developer Preview 5… is instituted:
— Landon Fuller (@landonfuller) Aug 5, 2014
Will be OK for TVPaint ?
I don't know (yet) how it will change things for us (if it does).
I think that this will only be the case for the softwares that are distributed via the App Store, which is the way most of the Apple softwares are distributed.
As TVPaint is not available in the App Store, I don't think we will be impacted by this change, but I will definitely inquire for more information tomorrow.
Thanks for warning us ! :)
ten_zero
Post by ten_zero »
furushil
Post by furushil »
ten_zero wrote:I report about a problem between TVPaint 10.5 32/64bit (both) original meny UI and OSX Marvericks 10.10 "accesibirity" setup.
Does this only happen with the "accessibility" UI setup? Or does it also happen with no UI changes?
Also a question to the team: Is it save to install OSX Yosemite 10.10 in general? I am thinking about upgrading soon.
ten_zero
Post by ten_zero »
Please wait a little bit, so we can finish the tests.
More informations next week.
ten_zero
Post by ten_zero »
Topic locked.
All discussions related to the newest version of Mac OS X should be in this topic
