Good question, I didn't find it in the manual either. Frankly - I don't remember how I started using it, but it was one of the first and most intuitive things I've learned in TVPaint, so I believe it comes naturally but anyway - a good point to ask why it's not in the manual (or why it's so hard to find if it's there)D.T. Nethery wrote:I have a question about the pen button as Right Click for erase . Most of the time I use the 'eraser end' of the Wacom pen to erase . I have read about using the pen button on the Wacom stylus (set to Right Click) to erase , but I've never used it like that (because I have my Wacom pen buttons set to other functions). (*NOTE: I can't find anything in the user manual about using Right Click to Erase last stroke and it's not listed in the Key Shortcuts commands for erasing. So I'm just curious: how does anyone ever know how to use Right Click button to erase if they don't read about it here on the user forum ? )
First thing to check is if DRYING is ON or OFF. When you set Drying off, then you can erase with the right click as much as you want. Drying on - only erases last stroke (for some pens it can erase several last strokes). I've noticed, that if the "last stroke" was some kind of an action, like line smoothing, then this thing doesn't work cause it just can't read the actual stroke. But there are all kinds of complicated tools, that might have unexpected behavior when in Erase mode. It depends on several other settings. Also keep in mind, that not all tools are actually drawing, so not all of them will of course erase. Some tools will undo themselves with right click instead of erasing something. Experiment with the Drying setting and you will see results.D.T. Nethery wrote:Here is the problem: the Right Click button to erase only works with SOME tools in TVPaint , but not all tools . Is this normal ? For example, there are certain custom brushes , such as "Chinese Brushes" and all the brushes from Creation Pack , and a few others , where pushing the Right Click button on the Monoprice pen enables me to erase the last stroke as expected. But with many of the other tools , including the basic set of pencils in the Tool Bin and the default Sketch Panel, the Right Click to erase does not work. Why would the Right Click button to erase work with some tools , but not will all tools in TVPaint ?
I am using the right click erase constantly, as the most important tool after the pen. Draw a line, erase, draw, erase, draw erase - easy. No need to flip the pen. On a Cintiq it's crucial for fast workflow. I do use the eraser tip for a bigger eraser to erase bigger areas fast.
